Old 20-04-2008, 12:49 PM   #1
4dlvr
4dlvr
Default My dash cluster is epileptic, wtf???
i go to switch my car on this morning, the car started up fine, but then i look at the speedo and tacho needles and they were shaking like they were having a fit...
what is their problem??? :
96 EF FAIRMONT
Garrett gt40 turbo , iceman plenum, head ported, polished and balanced, wade turbo cam, wade double valve springs, bosch 023 fuel pump, 36lb injectors high flow cat, 4' dump and 2.5' redback exhaust.
215rwkw @7psi
4dlvr is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2008, 12:53 PM   #2
Sterling
dont know those cars too well, but probably a lose ground wire or lose clips on the gauges... is everything having a fit or just the speedo and tacho?
Sterling is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2008, 01:00 PM   #3
4dlvr
4dlvr
its almost as if the dash cluster is delayed for about 2 seconds. then everything is fine.
it just has its little fit, and everything is fine.
ive been starting and switching the car off for a few hours now just to examine it, i realized if i wait a couple seconds while leaving the key on iii it doesn't do it, where as if i just put the key in and start the car rite away it will almost certainly do it
96 EF FAIRMONT
215rwkw @7psi
Old 20-04-2008, 03:46 PM   #4
photn
AFF Post NAZI
photn's Avatar
the LR's are known for their dash problems. i know Melbzetec's Dash deciedes to play dead whenever it wants.
Mine atmo is having issues, but i know its cause of the wiring harnes which i need to get fixed.
Old 20-04-2008, 05:54 PM   #5
melbzetec
Old enough to know better
melbzetec's Avatar
Mine is still not fixed, but my research suggests it is a result of dry solders behind the dials. Apparently one potential fix (yet to do it) is to remove the instrument cluster, spray the back where all the connections are with WD40 or similar and let it dry. Not a 5 minute job, and no guarantees
Old 23-04-2008, 12:19 PM   #6
HPB
Mine is still not fixed either. I removed the cluster and sprayed all the circuit boards, connectors, etc, as suggested on some UK websites, but to no avail. I've also gone around and cleaned and tightened all the earths. There is one behind the drivers kickpanel which is the actual cluster ground, but nothing has made a dffierence thus far. I'm going to put a new battery in my car and see if that changes anything - it's the original 5 year old battery, and I've seen dud batteries cause all sorts of issues in other vehicles, so I'll give that a go. If that doesn't fix it, I'll try and pick up a second hand cluster.
HPB is offline   Reply With Quote Multi-Quote with this Post
Old 24-04-2008, 08:23 AM   #7
melbzetec
melbzetec's Avatar
Damn. I was hoping the removal and WD40 spray approach would work.
I've got a new battery, but still getting the intermittent problem.
I'll do it anyway, but looks like more searching.
Maybe I just replace with a Motec dash!!!!!!
Old 24-04-2008, 11:28 AM   #8
photn
AFF Post NAZI
photn's Avatar
ill take one as well..
Old 24-04-2008, 09:01 PM   #9
eXtremist
2007 Ford Focus Zetec
eXtremist's Avatar
It happened to my focus after it had a flat battery.
I think it does it every 60 starts and every time u do a hard reset on the ECU.
eXtremist is offline   Reply With Quote Multi-Quote with this Post
Old 29-04-2008, 09:00 PM   #10
4dlvr
4dlvr
after several hours of kicking the dash, flaming at earth wires i cant find. i decided to change the battery and it worked. shiit, if only i got off my *** and tried it earlier
96 EF FAIRMONT
215rwkw @7psi
Old 29-04-2008, 09:20 PM   #11
melbzetec
melbzetec's Avatar
A bit more research today.
If it goes epilectic.....it will be the battery getting low on charge.
If speeddo and tacho just die for a few seconds or minutes, (rather than dance about) it can be a faulty VSS....vehicle speed sensor..which is apparently in the back of the gearbox casing
Old 30-04-2008, 12:04 PM   #12
photn
AFF Post NAZI
photn's Avatar
thats gonna cost you alot to get fixed
Old 30-04-2008, 05:27 PM   #13
melbzetec
melbzetec's Avatar
Not necessarily. The part is only about 25 pound in the UK, and is accesssible from underneath the car.....you don't have to open the gearbox
