Old 27-03-2008, 08:19 PM   #1
inertiac
Default 97 Mondeo Thermo comparison
Hey, just picked meself up a 1997 Mondeo and I've noticed the temp gauge moves about a lot, and gets quite high. I found a pretty useful page on common Mondeo problems, which says that they normally read high, so I'm not too worried, but when waiting at traffic lights etc I can see it rise to the 'L' in NORMAL. Just wondering what everybody else with a Mk1/mk2 model considers normal temp gauge behavior, with Australian weather?
inertiac is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2008, 08:39 PM   #2
paulie0735
paulie0735's Avatar
If it were mine I would get it checked out by a reputable cooling system specialist. They will be able to tell you what’s 'normal' and what’s hot.
paulie0735 is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2008, 09:35 AM   #3
Simon_Koala
Starter Motor ?
Mine does the same (its also a '97 Mk2), but according to what info I'm able to gleam from searching the net, its normal. So I am not worried. I had a cooling system pressure test and flush done a few weeks ago by my local Ford dealer, and they filled it up with the (expensive) Ford approved coolant and it didn't change the way the water temp dial operates, so that pretty much confirms that it does run on the higher half of the temp scale dial. When asking the service manager, he confirmed the same - that Mondeo's just tend to run hot compared to some other cars.
Simon_Koala is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2008, 07:22 PM   #4
jared79
Sock Puppets
jared79's Avatar
No probs with mine. Sits at about 90 deg and stay there.
Ford Mondeo Zetec Hatch in Blue Ambition
jared79 is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2008, 09:19 PM   #5
apstar
apstar's Avatar
Does the Mondeo have an intercooler for the turbo?
apstar
apstar is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2008, 08:19 AM   #6
OZXR4
formally ozmondeo
OZXR4's Avatar
Mine had the same problem then it stopped working, it is a fault in the engine temp sensor.
2008 Fiesta XR4 Sea Grey
OZXR4 is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2008, 08:11 AM   #7
Simon_Koala
Starter Motor ?
Where does the needle now sit when operating the car in normal conditions, now that the fault has been fixed ?
09 Ford Focus LV XR5
