Old 26-03-2008, 04:52 PM   #1
profit_trd
Default ECU Code?
guys, just want to know: i'm trying to find ECU code (i'm thinking about flashing the ECU). Don't know where I can find the ECU code?
thanks
roy
profit_trd is offline   Reply With Quote Multi-Quote with this Post
Old 26-03-2008, 10:05 PM   #2
paulie0735
paulie0735's Avatar
http://www.dreamscience.eu/flashtuni...page/Itemid,1/
paulie0735 is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2008, 02:47 AM   #3
profit_trd
do i need to know my ecu code if i want to order from dreamscience? because focussport.com and other ecu flasher usually needs the car's ecu code. if so, i don't know how to find my ecu code.
thanks
Old 27-03-2008, 09:41 AM   #4
melbzetec
Old enough to know better
melbzetec's Avatar
On the Mark 1 Focus, it was printed on the ECUitself, plus a small sticker on the inside of the front door jam. Not sure about MarkII
Old 29-03-2008, 05:52 AM   #5
profit_trd
i couldn't find any documentation about where i can find the pcm code. Even the sticker near driver's door doesn't contain 4 digits code.
Old 29-03-2008, 09:57 AM   #6
paulie0735
paulie0735's Avatar
........ get in contact with one of the tuners like Dreamscience, (you will need them to flash the ecu anyway) they will tell you 'exactly' what info about your car they need and 'exactly' where to find it.
