Old 21-02-2008, 01:17 PM   #1
beno6699
Default Speedo not working
Hey ppl i got a fairmont au II and just last night i was driving home and the speedo stoped working. No matter how fast i got the speed wont go up past 0km even in reverse. Is this a fuse problem or wiring?? Every thing else on the dash appears to be working like the rrp go up when i reve the car. Also it dosnt appear to change gears either is that because it does not work without the speedo??
beno6699 is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2008, 03:52 PM   #2
tickford90
I had a similar problem with my 2000 model. Mine use to as you were driving along just read zero on the speedo and stay in third. Then it would go back to normal every 5 mins. My problem was in the actual dash cluster which I replaced with a 2nd hand one which works excellent now. Apparently it is a very common problem. Also mine happened at 270 000 kms. Hope this helps.
tickford90 is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2008, 02:25 PM   #3
ed4lt
beno6699,
Have you fixed your speedo yet i have the same prob, and would like to know what was wrong !
Any help would be good !
Cheers Mate !
ed4lt is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2008, 09:58 PM   #4
Au2falcons
Winter all year round
It can also be the speed sensor attached to the side of the gearbox (also known as the transducer).
When this goes the car will go into limp mode so the gearbox will be stuck in third. Costs about $80 to fix.
Some people drive sports cars on the weekend....I drive my AU! It's not what you drive...it's how you enjoy it.
Recommend trading with Mechan1k, Offyaguts, EDMONTY, PhantomXR8, HOTC2R, Partie & JC
Au2falcons is offline   Reply With Quote Multi-Quote with this Post
Old 18-09-2022, 06:23 PM   #5
Mighty_Windsor
Default Re: Speedo not working
Thanks AU2 Falcons i am going to try this before spending 260 for a BTR shiftkit
Mighty_Windsor is offline   Reply With Quote Multi-Quote with this Post
