Old 19-02-2008, 05:12 PM   #1
AUTOCAD1
Default Wipers
I want to replace the wipers (just the rubber) on the wp fiesta. Are there any good aftermarket ones or should I just buy them from ford.
Also what size do I need to get?
thanks
AUTOCAD1 is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2008, 06:09 PM   #2
Adsy01
Adsy01's Avatar
They're 24" IIRC
I personally use any silcon type replacement, the rubber ones don't last long in the sun
They shouldn't cost anymore than $10 a pair from a department store, or even cheaper at a repco, bursons etc..
2004 Fiesta Zetec
Colorado Red
Elbach Lowered Coils - Rear sway bar - 12.5mm Axle Spacers - Rear disc brake conversion - 16" MP3 Rims
Tinted windows - Tinted Headlight surrounds - Clear side indicators- Phillips Xenon lighting - Colour Coded - ST Rear Spoiler - Smooth Rear Wiper - Ford leather gear knob & boot – Zetec S Sill Covers & Steering wheel - Leather centre armrest - Pioneer USB/CD player - JL Audio 4ch Amp, subwoofer & splits - Short aerial
The most "Standard" car I've ever owned!
Adsy01 is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2008, 07:12 PM   #3
melbzetec
Old enough to know better
melbzetec's Avatar
A bit more than just the rubber, but check out Bosch Aeros Twins at Supercheap Auto.
Brilliant.
Whisper quiet and far more effective performance.
(Probably about $50 for the pair....but some guys I know say it's the best bang for buck mod they've made!)
http://www.bosch.com.au/content/lang...l/715_5615.htm
Old 19-02-2008, 07:32 PM   #4
zetec jim
04 fiesta zetec
zetec jim's Avatar
Brilliant.
i'll second that, got some a little while ago, they are a lot quieter and look awesome! just look on the back and see if they fit an LR focus, mine worked fine. but just test one first to see compatibility. i think i got a 22" and a 16". just measure your existing ones with a tape and try and match em.
zetec jim is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2008, 08:11 PM   #5
Adsy01
Adsy01's Avatar
I was tempted to try these when i recently got my new wiper blades
Silicone blades work 100% effectively as they are designed to, and are whisper quiet... but the bosch ones do look pretty neat :
but other than looks i didn't think they were worth the extra cash IMO..($ x5 = : )
If you want a noisy blade try those twin ones... I unfortunately did once and they bloody whistled at speeds above 60KPH :togo: we live and learn i guess
2004 Fiesta Zetec
Colorado Red
Old 19-02-2008, 09:19 PM   #6
zetec jim
04 fiesta zetec
zetec jim's Avatar
EDIT: actually i bought the Aunger ones. little cheaper, look the same. but i haven't had any troubles with whistling over 60kmph. dunno how long they last though......
Old 19-02-2008, 10:56 PM   #7
melbzetec
melbzetec's Avatar
I previously used silicone blades.......squealed like buggery
Old 20-02-2008, 09:43 AM   #8
AUTOCAD1
thanks for all your quick replies. I'll check them all out and let u know which ones I got in the end.
