Old 05-02-2008, 01:25 PM   #1
sturty_tx5
elmo
Wink f20c in a tx5
hey just wanting help with a converion im doing. im putting a f20c from a honda s2000 into my 1990 ford telstar ghia. does any1 have any tips to make this easy. i can get any i need made up as my father is a qualified panel beater/mechanic/fabricator/electrician.
sturty_tx5 is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2008, 03:10 PM   #2
dirty hands
Over Thinker
dirty hands's Avatar
just weld up the new engine and gearbox mounts to suit
rewire the computer electrics to run the honda motor
fuel pump and efi running gear to suit
if using a ford manual gearbox an adaptor plate/shim for the bell housing
check the splines on the CV joints for length and the brake rotor choice
you will need a brake upgrade
gearbox shifting cables
bit of pipeing for exhaust then a machinery certificate
http://en.wikipedia.org/wiki/Honda_F20C_engine
just read this bit
It is the only Honda 4-cylinder engine that is designed to sit longitudinally for rear wheel drive.
like to see this run east west and how you are going to run the coolant pipes
keep us posted on your project
My car goes Brumm Brumm
Old 07-02-2008, 04:05 PM   #3
sturty_tx5
elmo
Question
ok most of that is simple except the adaptor plate/shim is going to be a little hard but i should get it done with a little bit of trial and error, and the coolant pipes have got me just a little stumped so im doing a bit of research to find some photos of exactly where the coolant enters and exits the f20c. Does any1 no where i could purchase a 1way lsd for the f2t gearbox? thanks for the help guys
Old 07-02-2008, 10:02 PM   #4
dirty hands
Over Thinker
you could fit a 12 volt water pump some are very good
use mdf / ply wood or card board for shim work material
then use aluminium as end product
if running east west choose one of the
hondas front wheel drive 5 speed manual g/boxs
Old 08-02-2008, 11:11 AM   #5
sturty_tx5
elmo
great idea with the water pump as this would give the added benifit of slightly better power and throttle response as i wouldnt have to use the belt driven pump any more and do you think a 1999 intergra type r gearbox be suitable?
Old 08-02-2008, 12:10 PM   #6
sturty_tx5
elmo
Angry project is OVER!!!!!!
my project is now dead because the motor i was going to buy turned out to have smashed pistons and valves!!!! AHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH HHHHHHHHHHHHHHHHHHHHH DAMN IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
