Old 18-01-2008, 11:33 PM   #1
sly
Sly like a G6
sly's Avatar
Default "New" Cruise Control Not Working
Got a cruise control module, wiring, switches, yoke etc from the wreckers. Fitted it today while I was fitting the new Momo wheel. On testing it, the stalk turns the "Cruise" indicator in the odometer panel on, but the steering wheel buttons don't work... it won't set a speed. All the wires are connected up OK, as is the cable to the throttle.
What I don't have is the braking module to screw into the master cylinder, so its electrical plug is just sitting there unconnected.
Do I need to have the braking module connected to set a speed or should I also be looking elsewhere?
Sleeper, anyone?
Old 19-01-2008, 01:24 AM   #2
sly
Sly like a G6
sly's Avatar
Dig around in enough manuals... I'd been under the impression it was a fancy way to apply the brakes to stop speed creeping up while going downhill... turns out it's a pressure switch that open-circuits when the brakes are applied, cancelling the cruise setting. No switch, permanent open circuit, no cruise. So back to the shop to get the missing part...
Sleeper, anyone?
Old 19-01-2008, 12:40 PM   #3
F6 R-Spec
formerly PURSUIT-250
F6 R-Spec's Avatar
Yes this is correct, you need the switch for it to work also fit a new one they tend to play up.
F6 R-Spec is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2008, 09:09 PM   #4
sly
Sly like a G6
sly's Avatar
Yup, fitted a new one today, all good now. Will be handy coming home from dogwatch over the long weekend with double demerits...
Sleeper, anyone?
Old 20-01-2008, 01:04 AM   #5
InfernoSR
Sales Representative
InfernoSR's Avatar
How much did you pay in total for the parts?
Old 20-01-2008, 11:31 AM   #6
sly
Sly like a G6
sly's Avatar
$165 from the wrecker for CC module/cable/fittings, wiring harness, combination switch assy (steering column stalks), steering wheel switch and anything else I forgot.... everything except the de-activate switch. The de-activate switch cost $38.90 new from Ford. So all up $203.90.
Standing on my head under the dash to install the wiring.... priceless!
Sleeper, anyone?
Old 23-11-2009, 02:14 PM   #7
Hords
Treasure your balls?
Hords's Avatar
5 minutes spent taking the seat out makes life a little easier under there...
Meteorite T3 TS50 ESS
Hords is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2009, 02:38 PM   #8
lofty
Rusticating
lofty's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Excellent article on AU Power window installation.
For the record, I believe it's also possible to bridge the pins in the socket, though I haven't tried it myself. I think that switch is just a backup for the brake pedal switch.
Territory SYII RWD, BFII RTV tray
lofty is offline   Reply With Quote Multi-Quote with this Post
