Old 10-12-2007, 05:36 PM   #1
ford-88
ford-88
Default engine rebuild
I'm thinking bout rebuilding my s1 engine with a race series kit of some sort, just wondering if anyone knows wat kits and prices
thanks
ford-88 is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2007, 08:40 PM   #2
Hibbz
The Mod Bug Has Hit
Hibbz's Avatar
Mate you would need a lot more info than that.
Type of Motor??
Budget??
Transmission??
Use??
How much you can do??
These all come into it.
Jake
www.aufalcon.com/jakesfalcon
Hibbz is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2007, 10:08 PM   #3
FS5
its around $1200 to $1500 including machining/ pistons/rings/bearings/timing kit and gaskets ,providing yo do all the labour yourself.thats for the bottomend.
just reread your question,an acl bottomend rebuild kit is around $700/$800
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17.
FS5 is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2007, 11:05 PM   #4
ford-88
ford-88
I've got a std I6, 5 spd.
My budget is bout 2.5 to 3k.
mainly street but want to put it down the strip
Old 10-12-2007, 11:28 PM   #5
OED666
OED666's Avatar
do you have any plans for boost in the future?
Powered by Rollin Motorsport
Turbo Barra ED 4L
OED666 is offline   Reply With Quote Multi-Quote with this Post
Old 11-12-2007, 03:58 PM   #6
ford-88
ford-88
yeah it on the plans on the spare engine i got. in bout 18 months
Old 11-12-2007, 08:37 PM   #7
RUKIDN
Missing the boost :(
Is it true that the ACL gear arent really recommended for boosted applications? Im able to get ACL parts through a friend and its something that could come in handy to me when the AU comes to 'rebuild' time but i recall reading there kits are not very suitable with forced induction... Any ppl with any helpful input/experience on this?
Cheers, chris
BA XR6 Turbo
301rwkw mild tune
Modified by XR6Turbo Developments
RUKIDN is offline   Reply With Quote Multi-Quote with this Post
Old 11-12-2007, 09:01 PM   #8
ford-88
ford-88
i was looking at acl kit au kits only come with cast pistons, also looking at the xr6t kits looks like the forged pistons will fit into the au. i could be wrong though
Old 12-12-2007, 12:39 AM   #9
blackers10
blackers10's Avatar
the valve reliefs in the pistons of the BA items are different to the AU items
i believe a custom set need to be made of which "HotRod" got done for his AU XR6T when he rebuilt the engine in that
so hed be the man to talk to
Old 12-12-2007, 07:41 AM   #10
FGII-XR6
FGII-XR6's Avatar
if you get the ACL race series without the raised compression pistons it will handle FI fine the standard race series are 10.2:1 compression IIRC a bit high for FI
Old 12-12-2007, 06:05 PM   #11
RUKIDN
Oh ok interesting, makes sense.. thanks mate its something i mite keep into consideration in time to come.
cheers chris.
BA XR6 Turbo
301rwkw mild tune
Old 12-12-2007, 06:17 PM   #12
sly
Sly like a G6
sly's Avatar
Chris, have a look at http://www.snortperformance.com/, scroll down to "Nuts & Guts", there is some good info on pistons & rods for boosted engines there. Not sure if what Brett says above is the same thing as the 20cc depression in the ACL pistons.
Sleeper, anyone?
Old 12-12-2007, 08:01 PM   #13
RUKIDN
Thanks for the link sly, i do recall seeing that in a past mag it had quite abit of handy info! Definatly given me something to think about for the AU.
BTW sorry about the thread hijacking ford-88 _2:
chris.
BA XR6 Turbo
301rwkw mild tune
Old 12-12-2007, 08:06 PM   #14
ford-88
ford-88
all good found the info handy to for my future project
