Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Blue Power Racing Developments
Blue Power Racing Developments The home of Blue Power. Website Link
Old 02-12-2007, 07:10 PM   #1
DJR02
Blown DJR
DJR02's Avatar
Default Valve springs
Hi,
I was just wondering, when you install a supercharger to a Boss engine you upgrade the valve springs?
Cheers Jeff
DJR320 build No 2
DJR02 is offline   Reply With Quote Multi-Quote with this Post
Old 03-12-2007, 08:59 AM   #2
Chris
AFF.com.au
Originally Posted by DJR02
Hi,
Cheers Jeff
Hi Jeff,
The quick answer is just "no", however, we make the recomendations that if a client wants to
*exceed 8-10psi boost
*run camshafts narrower than 112lobe with extra lift
*use the car for competitive use
we recommend upgrading of pump gears and valve springs. On our Blower option engine, all these things are included, however when someone "starts" on a blower program at say, 300-330rwkw, you will find it wont be long before the addiction takes over, and 400 becomes the target, then 500, etc etc.
We take it on a case by case basis, and as cases do vary, we warn people, and leave it at that. A smart client will heed advice and follow a sensible program, and have trouble free motoring.
Chris is offline   Reply With Quote Multi-Quote with this Post
Old 03-12-2007, 05:46 PM   #3
DJR02
Blown DJR
DJR02's Avatar
Thanks Chris
DJR320 build No 2
Old 04-12-2007, 03:50 AM   #4
wodahs
wodahs's Avatar
Originally Posted by Chris
Hi Jeff,
ive seemed to have hit this extreem but while the lot is wide open might aswell do it all there and then
yes still (as money n time permit) doing the
rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually
just remember don't be afraid to try something new.
Remember, amateurs built the Ark...Professionals built the Titanic!
I have taken up meditation... at least it's better than sitting around doing nothing !!
wodahs is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2007, 09:39 AM   #5
Bluepower
KenneBell Australia
Bluepower's Avatar
Yep - good idea. How's the project coming along??
Bluepower Racing Developments
Proud Australian Distributors of Kenne Bell superchargers
The Quickest, The Fastest, The Baddest Boss Blower of all.
www.bluepower.com.au
Bluepower is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2007, 03:28 AM   #6
wodahs
wodahs's Avatar
dash is in but commin out just after chrissy for sand blasting and body work
heads are finnished just gotta get the cams again just after chrissy
monies dryin up abit at the moment ( buyin a house now too ) but will post more pichs in me project area in the mext few weeks
