Hi everyone. I recently brought a series 2 AU XR8 auto with about 100,000k's on the clock. It is a beautiful car and I love to drive it. Ive noticed a couple of times when driving if I accelerate hard it seems to hesitate for a second (long enough for it to be uncomfortably noticable). I tried looking through some old posts but I couldnt find much on it. Is this a common problem? What could be the cause of the problem? I originally thought it might be the adaptive shift not being use to how I wanted the car to react but today i jumped on the accelerator from a stop, it took off, built up a bit of speed and as it changed into second it hesitated (almost like it was choking) then it finally changed the gear. Thanks for the help guys.
Young !@#$ Head
first thing id check is maf and throtle body that sought of thing. Give them a clean to make sue it's getting the correct air fuel mix. Just a suggestion. I've never had that problem with mine???
www.aufalcon.com.au/blackauxr8 AU3 220 XR8 CUSTOM PEARL PAINT LOWERED THEN LOWERED EVEN MORE ADVANTI 20's K&N PORTED MANIFOLDS TWIN 2 1/2 into 3 inch PIPES 244rwhp NOW WITH T5 5 SPEED COBRA CLUTCH AND BILLET LIGHTENED FLYWHEEL SUZUKI GSX-R 750 BLACK 2007 MODEL CARBON FIBRE YOSHI PIPE |
i have always thought that because auto gear box is using liquid its going to be slow to react because you have to get the liquid moving....but what do i know.
Many Thanks 2001 AUII Factory LPG Manual XL Styleside Box High series bonnet Clear Side Indicator K&N Air Filter BAXR6T Snorkle Low Fronts, Super Low Leafs |
Formerly MR BAXR6t
ive got a manual xr8 and the same thing happens too me some times, not when taking off, but while your gaining speed seems like a slight slip/miss. Not hugely noticble but enought to annoy u.
Current car 94 ED Fairmont 5L in Burgundy Fords ive owned- 2010 FG XR6 5 speed auto in Mystic 81 XD S-Pac 302c 4sp manual 78 Yellow TE Cortina Wagon 4.1L 92 Green EB Fairmont GT replica 01 Black AU XR8 II Manual 04 Rapid BAII XR6T 220rwkw 04 Mandarin BA XR6T 247rwkw 07 BF II XR6T 385rwkw 1980 ZJ Fairlane 302c |
Young !@#$ Head
You can set your auto's adaptive shift so its on max all the time so it will rev out more but it wont stop your problem
Thanks for the help. Its starting to be less of a problem now that im use to it, im sure its just a slow reaction from the gearbox as mentioned above . Less noticable in max performance.
Ya.. ever time i get out of my car and drive my mum car or other mates that have auto they all feel slow
