Old 17-11-2007, 12:20 AM   #1
Joekar
Default KF Laser - bleeding cooling system
Is there any requirement to bleed air from the cooling system when changing coolant?
If so, where are the bleed points?
Joekar is offline   Reply With Quote Multi-Quote with this Post
Old 17-11-2007, 09:23 AM   #2
dirty hands
Over Thinker
dirty hands's Avatar
you can squeeze the top and bottom radiator hoses to expell air
turn heater on
check level after the thermostat has opened
on other cars
if the temp sender was at the top of the inlet manifold you could undo it
My car goes Brumm Brumm
