Old 02-11-2007, 09:02 PM   #1
Mental
Cam Luncheon
Mental's Avatar
Default Cortina Power Steering Q's
I have a recently purchased a TF cortina Speedway/race car and it has a power steering rack but no pump. Seems they wanted a higher ratio box for quick steering but weren't to worried about the power part!
Question is, can I use a power steering pump from a falcon 6/v8 or are they different. Also, on the rack which hole is pressure and which is return. cheers.
-- Any problem is best approached sideways ... with a crowbar --
-Mental on Life, the Universe and Everything.
Mental is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2007, 01:06 AM   #2
Mental
Cam Luncheon
Mental's Avatar
Anyone?
Old 10-11-2007, 06:25 PM   #3
v8boss
Depends what rack it is, being a speedway car, it might have had something different grafted in. But regardless, yes, any pump should do, as the principals of power steering are the same regardless, = engine turns pump, pump pushes fluid, rack works easier. I use a toyota MR2 electric pump, which works real well. The bigger hole in your rack is for the return usually
bigger Is better.
v8boss is offline   Reply With Quote Multi-Quote with this Post
