Old 01-11-2007, 11:06 AM   #1
cars
Exclamation 92 V6 AX Telstar TX5 - unstable idling speed and momentary loss of power
Hi Everyone.
I've got a problem with my 92 V6 TX5. When the engine is warmed up or when for half hour or so and the let the car idle the rev starts 700 rpm. About 1 minute or 2 later it went down to about 600 rpm then 500 until it is very low when the engine is about to stall and very shaky then the engine revs back to 700 rpm. This process repeats over and over. I also experienced a moment (1-2 seconds) of loss power while the car is travelling at 60-63 km/h. This problem is only occurs when the engine is warmed up and it happens intermittenly. I've had it rocker cover gasket both front and rear, cam seals, distributor and timing belt changed the last couple of weeks. I've also had new sparks, air filter and new spark plug leads changed. Does anyone had experienced these problems or know what could cause these problems? I would like to hear from you. Thanks in advance.
cars is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2007, 02:13 AM   #2
dirty hands
Over Thinker
dirty hands's Avatar
check these
if the car is fitted with them
a stepper motor at the throttle body
the computer control unit for the motor
the air flow meter in the air filter if fitted
fuel filter
or if your model has the acellerator pedal as an electronic switch type (at the pedal )
My car goes Brumm Brumm
Old 05-11-2007, 10:31 AM   #3
cars
Thanks for the suggestions.
Much appreciated. The stepper motor is that the idle speed motor. The mechanic had check and clean the whole throttle part including the idle speed and said they are ok.
Old 05-11-2007, 12:49 PM   #4
dirty hands
Over Thinker
the computer control unit for the motor / would be my next item / have a diagnostic done
Old 05-11-2007, 12:50 PM   #5
BlackLS
yum
Vaccuum hoses?
2005 LS Focus LX
250,000kms.
