Old 29-09-2007, 09:27 AM   #1
lup1
Default 1991KF laser giha
The auto in the car has died and would like to have a go at replacing it myself with a change over (if i can get one ).Any tips would help thanks
lup1 is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2007, 06:36 PM   #2
dirty hands
Over Thinker
dirty hands's Avatar
general procedure to take out a FWD auto
get a good one from a wrecker
undo outer cv nut - large socket and lever bar have someones foot on the brake pedal or in gear or park
jack up car put on stands undo both front wheels
drain auto oil /remove both drive shafts by undoing tie rods and front lower shock strut nuts
undo battery and starter / gear cables /wiring to the box /undo drive plate nuts to torque converter might be a plate at the end of the sump to remove
undo rest of gearbox nuts held to motor
lower gearbox with a jack
make sure the torque converter is in the box properly
My car goes Brumm Brumm
