FPV GT Owner!!!
Hi all,
My mother has a 91 SA ford capri convertable. The car is a fuel injected model. The problem is it will go through stages where it will not start through the ignition. It will always clutch start, but wont fire when cranking over. Then all of a sudden it will start for a few weeks without a problem ?????? Have checked timing, leads, plugs, filters... stumped. Any ideas?
Cars: - Ford Ranger Wildtrak - XY GT Replica - XB Coupe Project |
If it is the 1600 DOHC engine, these had a few issues with coils and distributors. Does the plug lead have spark at it while cranking? Does the engine sound normal when cranking, or does it wind over faster than normal? Could be the valves holding open as well if it has the wrong oil in it too. Just a thought, would need more info.
bigger Is better. |
fordv8uteman
hi, mine also does this sometimes upon starting it only clicks and wont turn over and in the manual it tells you that if this happens depress the accelerator about half way while starting, hope this helps..
Hi BOOSTDEF, sounds to me like one of two things.
