Old 31-07-2007, 03:06 PM   #1
TEaaron
TEaaron's Avatar
Default Boss kit made my wheel sit about 45mm closer to me
Not sure what area to post this in, but I put a boss kit and aftermarket steering wheel in my te yesterday and now the wheel sits about 45mm or so closer to me.
Is this normal or did I do somthing wrong?
TE cortina 14.0 @ 101mph
E32 740iL Leather, sound system, rollin' on 19's
TEaaron is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2007, 03:11 PM   #2
Whitey-AMG
AWD Assassin
Whitey-AMG's Avatar
I had the same issue in my XE ESP.
I got SAAS to machine down the BOSS. This was done Free of Charge when I spoke to them about the issue I was having.........mind you this was about 10 years ago.
You might want to try the same thing ???????
You just have to watch the depth of the retaining hex bolts. It may be necessary to get shorter units. Off memory, SAAS had to re tap mine.
Whitey-AMG is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2007, 04:34 PM   #3
Full Noise
Life begins at 40
Full Noise's Avatar
Location: Melbourne. Socialist capital of Victoriastan.
There’s actually two different sized steering columns with the TE Cortina. The longer column is in the Ghia which has the four spoke wheel with a huge plastic spacer behind it. The GL has a much shorter column, approximately three inches shorter.
Marriage is like a deck of cards. In the beginning you’ll have hearts and diamonds. Towards the end, you’ll be looking for a club and a spade.
Justice is what you get when you run out of money.
Full Noise is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2007, 05:54 PM   #4
TEaaron
TEaaron's Avatar
mines a GL and has a plastic spacer.
I cut the edges off the platic spacer that use to go onto the steering wheel and put the boss kit infront of it as you can see the metal shaft without the plastic spacer..
The boss kits seems to be on alright but it pushed up against the plastic spacer when you tighten the bolt.
Old 31-07-2007, 06:12 PM   #5
xbcool
dazed&confused
xbcool's Avatar
after much measuring and studying of a te the only easy solution to your problem is to move the seat back 45mm. :
ban frangipanis
beauty is only skin deep.
ugly goes all the way to the bone.
xbcool is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2007, 07:24 PM   #6
TEaaron
TEaaron's Avatar
It's dark, hard to take a decent photo.
Old 31-07-2007, 11:35 PM   #7
Van D
Van D's Avatar
Are you sure you couldn't get a different boss? I had the same problem with my XF, and took it back to where we got it and swapped it with another boss that was much thinner.. Problem this time was that it was too close to the indicator stalk, so we had a spacer made up by a local engineer for 20 odd bucks and it worked a treat.
Originally Posted by irlewy86
Holden made the decision to make thier utes for pretty boys years ago. Wannabe tradesman drive them. If my son came home and told me he bought a holden ute I would struggle to come to grips with the fact he is a homosexual.
Van D is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2007, 07:14 PM   #8
myxr6
Maybe you need a deep dish boss.
myxr6 is offline   Reply With Quote Multi-Quote with this Post
