Old 16-07-2007, 06:50 PM   #1
MADED-6
MADED.6
MADED-6's Avatar
Default where to find engine number
hey people i have an eb with turbo au motor i need to know where to find the engine number.
cheers josh.
TUFAU-8
Get Stroked.
AU Stroked 5.6L GHIA
MADED-6 is offline   Reply With Quote Multi-Quote with this Post
Old 16-07-2007, 06:56 PM   #2
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
on the compliance plates on the AU it came off , or the Block ..
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 16-07-2007, 06:58 PM   #3
Bucknaked
Bucknaked's Avatar
cheers josh.
Did you buy the maroon one that was for sale recently on the forums?
Old 16-07-2007, 07:07 PM   #4
MADED-6
MADED.6
MADED-6's Avatar
yeah i did bucknaked and where is it on the block.
i cant see it.
ill have another look but if someone knows which side or where abouts exactly it would be muchly appreciated.
cheers josh.
TUFAU-8
Get Stroked.
Old 16-07-2007, 07:12 PM   #5
MADED-6
MADED.6
MADED-6's Avatar
and also how long it should be.
i have a number but its like 10 letters and numbers.
i dont think it would be that long.
cheers josh.
TUFAU-8
Get Stroked.
Old 16-07-2007, 07:13 PM   #6
FGII-XR6
FGII-XR6's Avatar
it's on the drivers side near the bellhousing about 2/3 the way down my engine number is 11 characters long
Old 16-07-2007, 07:16 PM   #7
MADED-6
MADED.6
MADED-6's Avatar
sweet as thanx man.
ill have a look but i got a big turbo in the way hopefully i can find it lol.
cheers josh.
TUFAU-8
Get Stroked.
Old 16-07-2007, 09:35 PM   #8
Sledgehammer
Sledgehammer's Avatar
yep just near the starter
Sledgehammer is offline   Reply With Quote Multi-Quote with this Post
Old 16-07-2007, 11:41 PM   #9
MADED-6
MADED.6
MADED-6's Avatar
that would mean its on the passenger side then.
i had a look at drivers side and cant find it so it must be the other side.
cheers josh.
TUFAU-8
Get Stroked.
Old 16-07-2007, 11:55 PM   #10
FGII-XR6
FGII-XR6's Avatar
no it is on the drivers side on an AU motor no where near the starter motor here is a pic the red oval is where the engine number is
Old 17-07-2007, 02:11 AM   #11
waggaclint
waggaclint's Avatar
yep drivers side rear near were the block bolts bolts to g-box
waggaclint is offline   Reply With Quote Multi-Quote with this Post
Old 29-08-2007, 12:38 PM   #12
private9
www.TUFFCARPARTS.com
private9's Avatar
Sorry all, do you have to get under the car to get the engine number? The car I'm looking at is LPG equipped, and I just can't see it through the top.
Lying under the car I can just see it though, but I'd prefer not to have to jack the car up if I don't have to!
Old 29-08-2007, 12:51 PM   #13
F6 R-Spec
formerly PURSUIT-250
F6 R-Spec's Avatar
Hi there, if you stand where the drivers side front wheel is and look down there will be a flat bit on the casting just under the exhaust manifold, it might be a little rusty thats why you cant se it also the number is dotted on . Use some emry paper to clean it up a bit, a lead light or torch will help heaps even if its a bright day. cheers mick
F6 R-Spec is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2023, 04:16 PM   #14
rooster77
Default Re: where to find engine number
Very much after the question was raised in this thread, but relevant for any who follow (like me, who just spent hours rooting around trying to find it)
My FG is the same - it's located where Mick (F6 R-spec) says in the post above.
I might be dumb, but it was still hard work even with that info.
In case it helps... I'll add:
it's perhaps 5 cm above the sump/block join, within a few cm of the bellhousing. The little flat bit of the block it's dot stamped on is not facing forwards, and not facing sideways....but more towards head level and angle if you're standing like mick says... next to the driver front wheel- so pointing a bit outward and upward.
You DON'T have to remove the exhaust manifold heat shield like I did (and still took ages to find it) You can see the area just underneath the heat shield, when looking toward the bellhousing/ block join just a little above sump level. I originally couldn't see any numbers, but when I saw a flat area of a few cm there, I wire brushed it and eventually saw the dots.
Page 201 of the owner's handbook shows the location, but the printed diagram was no help at all to me. When I looked at a PDF of page 201 it was (just) a bit clearer, but misleading because they show it facing directly forward, which it is not.
If this helps just one boofhead like me, my time was well spent.
cheers
rooster77 is offline   Reply With Quote Multi-Quote with this Post
