24-05-2005, 02:59 PM | #1 | ||
hibernating
Just wondering are 2 standard 1.9mm ford shims enough shimming for a DEV3HL cam in an EL? Also is it the same amount of shims for a DEV5 cam or would that need 3 standard 1.9mm shims?
24-05-2005, 07:56 PM | #2 | ||
Two > One
If you have the JMM cam there measure the Base circle diameter and work out the diffrence between the stock and the JMM cam. 1/2 the diffrence is how many shims you will need. I remember somone saying the dev5 had a 3mm reduction in base circle diameter, so you would need 1.5mm of shims.
I would say the cams would need 2 shims.
24-05-2005, 09:22 PM | #3 | ||
TL40 Wagon?
i used two shims plus the original all worked fine!
24-05-2005, 10:13 PM | #4 | ||||
RIP...
Rick.
. Oval Everywhere... |
24-05-2005, 11:31 PM | #5 | |||
Two > One
For some dumb *** reason i forgot which side the HLA was on!! Durh. 2*(BCD(stock)-BCD(dev5))/2) = shim height required.
25-05-2005, 08:16 AM | #6 | ||
Prince Of Darkness
2 shims plus standard on my au dev3hl
Engine; 351 Crank, 302 Rods, Custom Pistons, Blue Print & Balanced Bottom End, Crower Stage 5 Cam (Cam Specs), , CHI 3V Heads. ENGINE PIC HERE Body: XD Fairmont Ghia |
