23-05-2005, 12:21 AM | #1 | ||
I Wish I Was A Post Whore
Sorry i know its not a ford but, can someone help
Put new engine in mates gemini the other weekend every thing is new motor. runs perfect but blows shit loads of smoke, Why is it so smokey?? |
23-05-2005, 12:24 AM | #2 | ||
Not your average EF Wagon
What color smoke and when?, idle, on accel or what? Whats the smoke smell like to you?
Power by HeadTech Performance Williamstown The recently SOLD 95 EF Wagon 5spd NA SLEEPER The Daily cruisers now *95 R33 Skyline GTS-T RB25DET *93 Lexus GS300 2JZ-GTE Car enthusiasts visit Unique Cars and Parts
23-05-2005, 12:42 AM | #3 | ||
its white smoke, was doin it all the time, now only when revs pick up, and its hard to say what it smells like it doesn't really smell
23-05-2005, 12:57 AM | #4 | ||
Solution Was Boost 4?, 6 & 8
looks like the rings are no good..
where did you buy the engine?
[SIGPIC][/SIGPIC]
AUTOTECH TUNED EDELEBROCK CHARGED 2017 GT Mustang Plenty of RWKW |
23-05-2005, 12:59 AM | #5 | ||
If the cars auto check the vac module isn't stuffed. I know quite a few people who have bought engines due to a $35 part being worn out. When worn you can suck the trans fluid into the manifold.
74 XB Fairmont (street car) 11.07@123.02mph. 08 LV Ford Focus XR5 (daily). Tuned by Hallam Performance |
23-05-2005, 01:03 AM | #6 | ||
rings would want to be good just got back from rebuild
its a manual, |
23-05-2005, 08:17 AM | #7 | ||
Valve guides/seals maybe,have you done a compression check?
FORD RULES OK The more I know ppl the more I love my DOGS. 2011 SY Territory Limited Edition TS 2000 AUII SE ute IL6 |
23-05-2005, 08:53 AM | #8 | ||
TL40 Wagon?
white smoke? not blue or black?
Not sure about rings then. Any possibility its sucking in auto trans or brake fluid from a stuffed vacum modulator or booster? |
23-05-2005, 05:58 PM | #9 | ||
Maybe the oil control rings are upside down? I've seen it on a car once - pulled the head off and the dishes in the pistons filled up with oil on the starter. Took ages to get the oil out of the exhaust, too. Glad it wasn't my car or me doing the work.
23-05-2005, 07:30 PM | #10 | ||
mmm might check breaks as we changed master and booster when we changed motor
23-05-2005, 07:44 PM | #11 | ||
It sounds like its burning oil. Could be a case of the rings by the sounds of it.
24-05-2005, 12:01 AM | #12 | ||
GT
sounds to me like brake fluid disconnect the vacuum hose going to the brake booster and plugit up run the engine for 5minutes and see if it still blows white smoke.
24-05-2005, 10:04 AM | #13 | ||
If its oil, wouldnt it be blue smoke? I thought white was when water was gettin into the motor.
24-05-2005, 10:32 AM | #14 | |||
havn't cheacked if its breaks yet, as he hasn't come around, will check it tonight |
24-05-2005, 06:45 PM | #15 | |||
