Hi guys I have an AU XR8 5spd and have boroken a bolt on the engine mount on the left hand has anyone got any tips on drilling it out and replacing it, i know the starter motor will have to come off because its the rear bolt but other than that any help would be great or would i be better getting a mechanic to do it? if so how much would i be looking at.
Any help apreciated, Cheers |
335 kw of goodness
My advice is, get one of those stud removal guys to do it. Thats who Ford use, this is a common problem with the A series Windsors, & they know how to do it fast & inexpencive.. You would stuff around with it for hours, & still not get it. These guy do it in under an hour..
CAUTION! STILL Contain's opinion's & fact's that may offend !!! ![]() 2012 GTP 213 black what was I thinking? NOW FOR SALE>> http://www.fordforums.com.au/showthread.php?t=11439680 |
![]() Join Date: Dec 2004
I'll second that ..I've used a guy up here where i work for broken bolts etc and these guys get broken bolts fixed in minutes for a very reasonable price.. I'm sure there'd be someone in your area.
Yes. This is a professional job. Snapped of bolts are a pain in my behind. And anyone else who snaps them off really! Damn its cold this morning!
RC NITRO TRUCK addict
snap on sell cobolt extractor sets , with left hand drill bits , usually undo while drilling ,if you have a drill with reverse
XR8 250 PURSUIT ,silhouette, manual, hardcover/spoiler FG F6 310 sdn XFT SY T awd terry LC GTR304 t350 9inch VK BT1 LSX 454R p/glide 9inch LX SLR LS3 p/g 9 current project |
I've done many of these and I was surprised at how easy they were to remove, the remaining part of the bolt is very easy to drill through also. I pilot drilled using a 1/8th drill bit then redrilled using 1/4 bit then used an easy out to remove the broken bolt.
I found what also helps is to drill all the way through the broken bolt and spray some Wurth Rostoff up into the hole. |
a.k.a PAULY
i had a bolt specialist come out and do mine as both of my left hand bolts were sheared off,it took him hours to get the rear bolt out and he had done this on fords before,he had to drill out the bolt and broke several easy outs in the process and had to collapse the bolt with a special tool ,i have now got hair line cracks in my block haeded towards the welsh plugs arrrgh
![]() It cost me about $120 to get these bolts out but if he had troubles i would have had definate troubles if attempted by myself
2002 silhouette pursuit 250 manual,brembos, 3.73,s 2002 blue print pursuit 250 in restoration 1995 WMW250(CR250) dirtbike fully road registered 1947 ford thames tipper V8 21 stud flat head 1939 ford beer barrel truck V8 24 stud flat head HZJ diesel ute HJ47 diesel ute |
RIP...
Bit of a thread mine...
I was underneath mine the other day changing oil and saw both passenger side bolts broken. Drilled into each bolt a few mm with a 4mm drill bit, stuck in an 'easy out', drill in reverse and out they came. The rear bolt needed a drill extension, so didn't need to remove the starter or anything else. Took about 10mins all up. Easy job.
. Oval Everywhere... |
Mopar or FoMoCar
Well I'm glad some of you guys found it easy! I've just had a bastard of a time getting one out - and it was the easy one! (Front passenger side) Broke two Ezyouts - and that was after drilling all the way through the bolt and squirting WD40 up into it and letting it sit overnight to soak through. The bastard was seized tight and took a special splined 6mm stud remover and a breaker bar to finally get out.
I still have the rear one to tackle and am slowly drilling it out with an extension bar and a hex-key drill bit. If you have to do this, do yourself a favour and centre-punch the bolt to get the drill bit centred and then drill a pilot hole and gradually enlarge it until you have a 6mm hole drilled and use a corresponding Ezyout to crack it. You may be lucky and be able to get yours out with a 4mm hole/Ezyout, but if it doesn't feel like its coming, go the next size up. Apart from being rusted in there, I reckon the mount pounding on the sheared bolt when it broke nailed it in there nice and tight. The next job (after getting the rear bolt out) is to find a decent flanged 7/16" grade 8 bolt to replace the original. Ford don't sell them anymore, and you can bet that - like me - if you replace an AU V8 engine mount with another bolt from the wreckers, it will be fatigued and probably break (this is the second time I've had to do this job).
408 Charger 5spd - 11.666@121mph /\:T:/\ AUII XR8 Rebel - 220kW auto Last edited by Chrysler; 05-06-2021 at 04:58 PM. |
ARP do engine mount to block bolts
Current Car: 2002 AUII LTD 408ci Windsor, T6 S488, TH400, 2 Piece Shaft, Helicial LSD 3.23 IRS Daily: 1998 Mitsubishi Super VR-4 Legnum |
#12 | ||
Mopar or FoMoCar
Cheers mate. I looked by bolt size instead of application, but found what I needed after your suggestion. Part ARP 150-3102
408 Charger 5spd - 11.666@121mph /\:T:/\ AUII XR8 Rebel - 220kW auto |
#13 | |||
This stuff is 20 times better than WD40. Penetrates much quicker and literally dissolves rust. Get some you will never be without it once you have used it
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust. AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl OWN THE ROAD |
#14 | ||
Oh joy.
I’ve just discovered 2 sheared bolts on the LHS on an AU XR8 I’ve just bought. ![]() |
#15 | ||
Get the bolt removal specialist in. Save you a lot of grief
#16 | ||
#17 | ||
Agreed
I had a bolt specialist come in to repair a customers car, repaired on hoist under one hour work for one bolt $110ish inc for repair, that is worth having done because they are a cow to get out
#18 | ||
I agree with the above comments. If you are not confident get a professional to do it. If you bugger it up with an attempt it will cost more to rectify. The Thread Doctor has good reviews online going back years. Are you in Melbourne Vic?
https://www.sau.com.au/forums/topic/...-stud-removal/
AUII XR6 VCT ute 20 years and still going strong! |
#19 | ||
![]() Join Date: Nov 2011
When i rang thread doctor at the time i had to do this, he wanted the car on a hoist with steering rack removed. If i knew how painful the job was going to be i wouldn't have started it and would have got him to do it.
#20 | ||
I reckon they will want it on a hoist but ask if they will do it on stands, they can only say no. You dont ask, you dont get. They probably can recommend someone who has a hoist
#21 | |||
RIP...
Since this post I've done at least another 10 or so. All been pretty straight forward, taking as little as 10mins and up to 1 hour at the most. Only 1 beat me but that had already been started by someone else who drilled into the bolt off center. ![]() I'll be having another go at that one sometime in the future though, it's coming out...
#22 | ||
my old AU did this every few months
i never used high tensile bolts just in case they snapped and i could not drill them out and use easy outs on them i think the issue lied in the flushness of the engine mount to block face, even after torquing them up there was still flex in the plate and snapped the bolt after some time and lots off hard take offs
CURRENT RIDES BA GT Mk1 #0009 - Narooma Blue SY Ghia AWD Black VZ LX8 Adventra Holden HX 50th Anniversary AU Saloon Car racecar 1980 GS1000ST - Wes Cooley Rep
#23 | |||
#24 | |||
RIP...
I had another attempt at this one and was successful with the engine in the car. Drilled right through it with a masonry bit and out it come with an easy out. I did need to fit a bigger bolt though as the thread was too damaged. Still haven't been beaten... |
#25 | ||
Next upgraded Mk1 Leopard
Thread miner
![]() UK
#26 | ||
Afterburner + skids =
Sorry for the thread mine, but I will be dropping the K Frame on the XR8 at some point soon, due to an oil leak from the sump gasket.
As far as I can tell, I have no engine mount issues, however is it worth replacing them while the K Frame is removed as a precaution? I'm not keen to fix what isn't broken, but if it's good preventative maintenance, I don't mind doing the job. Any advice much appreciated.
#27 | |||
#28 | ||
Thanks Brandon. So replace the bolt and leave the mounts themselves alone then?
#29 | ||
Yep leave mounts nothing wrong with mounts just swap the bolts out torque to new ARP spec
#30 | ||
Id be doing the mounts if you've already got it apart.
If it's lasted near 20 years, then another decent set should last just as long so you can then cross it off the list of **** to worry about.
