ASL automedia Specialising in the upgrade of BA/BF/Territory and FG audio and visual systems. We also repair all Ford (OEM) car stereos and produce OEM quality wiring harnesses. Website Link |
Spooler
Hi Guys,
Just looking at you site and was hoping for a bit more info on the Low Level Output conversion you do.
Sorry for all the questions Thanks! Chris. ![]() ![]() ![]() |
Spooler
Sorry just saw the price on the web! my mistake :(
XR8 Driver
I have had it done by ASL and I can provide you with some of the information. This information was provided to me by ASL.
I believe the maximum output is 1V. I am driving JVC power amps and the attentuators on the amps are about halfway. I have Front L-R Rear, L-R and Subwoofer outputs. It all or nothing. If you want line out, the internal power amps are disabled. The trigger is a voltage applied to the wire when the ICC is on. It works well with both my JVC amps. As I have mounted the amps on the underside of the parcel shelf, I purchased good quality RCA cable with double shielding. I also used very good earthing including an addition each from the battery negative to the chasis. Result - no interference noise at all. You could say it acts like any other head unit. Price - if you already have a colour ICC, then the conversion is relatively cheap. I think it is on the web site. All the above information applies to the colour ICC. If you have the basic sound unit, I believe they can't provide a separate subwoofer output. If you want any further infromaton contact Fadi at ASL Logistics. fadi@asllogistics.com I hope that helps Good luck |
#4 | ||||
Spooler
Going by the above, I'm assuming you have the amps upside down on the parcel shelf. If this is that case I would re-consier that option. Amps have a heatsink on the top side for a reason and I would guess that you would render your amps prone to more heat and diminshed response resulting from the heat rising? Quote:
I thought that was the point of this section of the forum so all people could see the response? Thanks Guys! Chris. Last edited by XR.Turbo; 14-06-2007 at 04:05 PM. Reason: typo |
#5 | |||
Sponsor
you can call Karl at ASL anytime to discuss the low level conversion. 0397991444. cheers fadi75
FROM FALCON BA THROUGH FGX, TERRITORY SX THROUGH SZ - ICC UPGRADES, REPAIRS & INTEGRATION SPECIALISTS AUTHORISED FORD REPAIR CENTRE website: www.aslautomedia.com.au email: info@aslautomedia.com AUDIO INTERFACES, REVERSE CAMERAS, SATELLITE NAVIGATION & VIDEO INTEGRATION ON FACTORY COLOR SCREEN |
Shockwave
Since having my unit converted to low level outputs, when ever i play a DVD the colour screen now has a pink tinge. any ideas on cause or a fix would be much appreciated.
Smells like burnt rubber
Who's adaptor are you using to interface the DVD to the ICC?
#8 | |||
Sponsor
if you done the complete conversion with us please call us with the invoice number so we can assist you with your query. cheers fadi75
#9 | |||
Sponsor
if you think i am not doing a good job on the forums please do report it to the right party. Thanks fadi75
#10 | |||
Sponsor
we do have the RGB Convertor kits complete with the Boss DVD players $720.00 cheers fadi75
#11 | |||
Sponsor
please see answers below Hi Guys, Just looking at you site and was hoping for a bit more info on the Low Level Output conversion you do. What voltage are the outputs? 1-2 volt peak-to-peakI gather there are 3 sets (Front, Rear, Sub?) Is there an option to still use the speaker level outputs for one channel and low level for the others? You can have up 2 five RCA’s-2 Front, 2 Rear and if your car currently has a Subwoofer we can add this line also.What do you use for a trigger for an amp? (there is a mention on your site about this) A circuit we place in unitAny problems with noise etc, or does it just act like any other H/U with RCA outputs? We have never had a complaint about noise.Any other info you can provide? That’s about it. How much? $220 Sorry for all the questions Thanks! Chris.
#12 | ||
how much would it cost to post the icc from 5110 to where eva u are in melbourne
#13 | |||
Sponsor
you have to check with your courier. cheers fadi75
#14 | ||
just wondering do you have to already have a sub for you too be able to add rca's input's
as i have the basic icc and want to add front inputs and a sub input |
#15 | |||
Sponsor
please call us to discuss 0397991444 cheers fadi75
#16 | |||
Shockwave
Yeah Fadi done by you guys. i am using the Alpine Vehicle Hub been working fine for 12months only had problem since low level outputs fitted. Just posted here to put the feelers out to see if anybody else has had similar problem. Been going to call you to discus but been flat out at work. |
