Old 10-09-2006, 07:47 PM   #1
st_boi
st_boi's Avatar
Default St170 Cluster
has anyone had any problems with the backlight on their cluster?
i have an ST170 but any help would be great.
i have taken it to ford, the car spent a week there and they stil didnt fix it!
ok well the problem is this: there is no backlight, so i cant see anything! the needles are lit up but thats it.
is this a wiring problem?
thanks for any help!
st_boi is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2006, 10:38 PM   #2
orsest170
WRC Fanatic
orsest170's Avatar
Is the dash light permanently out or is it just happening intermittently ? My dash display went out about 3 times during the year that I had the car, and it seemed completely random.
Each time it happened to me, I simply parked up, turned the lights off, killed the engine and restarted again – Don't ask me to explain the logic, but it fixed it every time. Well, it isn’t really fixing the problem, but it would appear that it is more beneficial than taking it to Ford!
You may also experience problems with the dash lights flickering. I simply dimmed the display to about 75% brightness and the problem was gone for good.
Anyway, best of luck getting it sorted.
Panther Black XR5T
Pro Alloy Intercooler| Angel Eye Headlights (black)| Eibach Prokit Springs| K&N Gen II 57i CAI|
Dreamscience| InPro Black LED Tail lights| Black RS GT wheels| 14.007 @ 100.55 mph
orsest170 is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2006, 12:06 AM   #3
st_boi
st_boi's Avatar
lol, yeah iv been through all that. at first it was what u went through, and strangely enough i would do what u did! lol
but now the light has gone for good. thanks anyway! hopefully someone here has gone through the same thing as this and knows the solution.
Old 11-09-2006, 12:23 AM   #4
Blue_ST170
Blue_ST170's Avatar
yeh the ST170 have electroluminescent guages that the normal foci dont. Mine do the same thing every so often, where the needles r lit but the rest is dark. I always fixed it by turning the lights off and back on.
It doesnt happen very often for me but if its happening alot ide ask for a new cluster. I dont think is the wiring cause mine r fine 99%of the time but still do it at random.
03' Imperial Blue Focus ST170
Bluefin Level 2 tune, Custom extractors, Hi-flow cat,
K&N panel filter, EBC Turbo rotors with Greenstuff pads.
Saving for: cat-back exhaust
Blue_ST170 is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2006, 08:46 AM   #5
melbzetec
Old enough to know better
melbzetec's Avatar
I'd suggest you check on ffoc.co.uk, but the buggers charge to be a member now. If it's a common ST170 problem though, they're likely to know
Manual 2003 Machine Silver 5 Door LR Focus Zetec.
Mods: Ford Racing CNC'd cylinder head milled .040", 3 angle valve grind. Ford Racing Stage II camshafts. Ford Racing cam gears. Ford Racing long tube header. Random Technology hi flow cat. Herrod 2.25" stainless cat-back. Pipercross Viper intake. CFM 65mm throttle body. 2000 ported intake manifold. Herrod Custom SCT tune. Eibach suspension. Quaife ATB diff. Wilwood 13" brakes. Custom ST170 leather interior.
www.cardomain.com/ride/2773918
melbzetec is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2006, 09:56 PM   #6
st_boi
st_boi's Avatar
yeah i use to do the lights on lights off thing...but that doesnt work any more. it has a new cluster in it, stil not working. i just figure the guys at SUNBURY FORD - hopefully someone is reading this that works there or knows someone. cant express how ****ed off i am.
anyway...they told me to my face they had fixed it but all they was f@ck up everything else, AND not fix the light.
Old 12-09-2006, 08:48 PM   #7
fordel
Tricolore Tard
Contributing Member
fordel's Avatar
They charge now ?
wow glad im still a member there
Chris
fordel is offline   Reply With Quote Multi-Quote with this Post
Old 14-09-2006, 01:21 PM   #8
n1kol1s
n1kol1s's Avatar
Same here ....I turn the lights off and then back on and they fix them selfs.
Did anyone had their cd player stop working and refusing to eject the cds out?
Then again it fixed it self out after couple of days...(((spooked)))
n1kol1s is offline   Reply With Quote Multi-Quote with this Post
Old 14-09-2006, 03:12 PM   #9
BlackLS
Posts: n/a
Originally Posted by fordel
They charge now ?
Chris
To access specific areas you'll need to pay.
Old 14-09-2006, 11:55 PM   #10
Blue_ST170
Blue_ST170's Avatar
my cd player does a weird thing on burnt cds where it will play fine some days but not others....doesnt matter if u turn the car on and off or take the cd out it just wont play sometimes.....
Old 15-09-2006, 09:17 AM   #11
n1kol1s
n1kol1s's Avatar
Yeah . That is what i mean... lucky me it happend only once.
