Genuine Ford Parts A forum for the purchase of genuine Ford parts via an AFF member. |
24-07-2024, 10:42 PM | #2071 | ||
Hi, are SX/SY Territory front diff bushes still available including the bush on the drivers side?
25-07-2024, 10:54 AM | #2072 | |||
SX SY Front Cross member.pdf SX SY Front Drive Shaft Housing.png |
25-07-2024, 10:59 AM | #2073 | ||
Have a look at the images below, in the first do you mean bushes labelled 3B177 and 3A443 in the second?
sx sy front cross member .png |
25-07-2024, 08:57 PM | #2074 | |||
Regular...with metamusal
5R29 17D927 AA and the other side is a 'bit' hard to read .. so i'm guessing- what i believe is - 5R29 17D926 AA these numbers are for the black/white eggcrate with the shaped top. so i have no idea what year they correlate too. |
25-07-2024, 09:43 PM | #2075 | |||
25-07-2024, 09:45 PM | #2076 | ||
Hi Gtlegend, are FGX XR headlights obsolete or is there new stock coming? Showing sold out on Jefferson ford.
25-07-2024, 10:26 PM | #2077 | ||
25-07-2024, 10:27 PM | #2078 | |||
The 5 in 5R29 means 2005 model year designation. |
25-07-2024, 10:37 PM | #2079 | ||
25-07-2024, 10:51 PM | #2080 | |||
So further more, from those engineering part numbers you mention, they cross reference to: 5R29 17D927 AA = BAF 17D927 A 5R29 17D926 AA = BAF 17D926 A |
25-07-2024, 11:04 PM | #2081 | ||
So the 3B177 has part number SX4B424A, obsolete but are some around:
https://www.ebay.com.au/itm/32596601...Bk9SR_SDgJydZA The 3A443 has part number SX3A443A, obsolete and nothing I can find at this point. |
26-07-2024, 10:38 PM | #2082 | |||
03-08-2024, 03:18 PM | #2083 | ||
Hi Legend . i have another of my questions
it's BA 15W204 AA - has ford BA cornering kit on the packet but i have NO idea what is meant. i'm presuming some sort of wiring loom?. Thanks |
03-08-2024, 09:46 PM | #2084 | ||
BA 15W204 AA is the wiring that goes from the cornering lamp to the loom on Fairlane/LTD.
03-08-2024, 09:57 PM | #2085 | ||
ok?. i don't remember any when i stripped the BA Fairylane RHS loom i have here, just the wiring loom going straight to the cornering lamp socket plug. i'm intrigued now lol.
04-08-2024, 04:36 PM | #2086 | ||||
understand your reply now. have seen what we are talking about in the flesh. Thanks |
04-08-2024, 05:22 PM | #2087 | ||
[QUOTE=mad2;6910269]ok. what is BAF13411A ?.
BAF13411A is "Position Lamp" bulb socket |
04-08-2024, 08:01 PM | #2088 | ||
04-08-2024, 10:35 PM | #2089 | ||
06-08-2024, 12:07 AM | #2090 | ||
Air filter to suit the Miami, I believe it's AR3Z9601A.
Is the going rate around $150? And is the part in short supply? It had only limit use in the US, so I wonder if it will become NLA.
06-08-2024, 03:06 PM | #2091 | ||
Part number is correct. price more like around $180. Plenty of supply from what I can tell..
20-08-2024, 09:47 PM | #2092 | ||
Just wondering if its possible to buy any FG Falcon Airbag to replace my current one.
Airbag hasn't blown but the Horn Pad Cover has a split down the middle and wanting to replace it. Is it a direct insert onto the steering wheel or do i need to do more? |
20-08-2024, 10:25 PM | #2093 | |||
They are held in by 4 bolts at the rear of the steering wheel. You must ensure you depower the system by disconnecting the battery and waiting time for the power to de-energise. How ever I would not recommend replacing anything airbag unless you are really qualified and know what your doing. Could end in disaster. |
21-08-2024, 09:28 AM | #2094 | |||
sorry GT but the FG/SZ airbags are not held in with 4 bolts. it clips in and a 'spring' holds the lower part in. to remove power down the cars systems (or at least the airbag systems) then i used a small torx allen key inserted in the hole at the base of the steering wheel airbag to release the clip so airbag 'pops' free. this is what i do to remove my FG airbag fitted to my BA - as per Gothefalcons instructions (). just make sure the airbag connections are correct as i found the SZ connector is differant (one of em to bag). cheers |
21-08-2024, 09:13 PM | #2095 | |||
22-08-2024, 11:47 AM | #2096 | ||
Hey Legend
Any idea what places in Western Australia stock the Genuine Ford Motorcraft Battery 560CCA and the retail price? Looking to get one for the FGX |
24-08-2024, 06:10 PM | #2097 | ||
24-08-2024, 06:22 PM | #2098 | ||
Giddy up.
What is the correct OEM Engine Air Filter element to suit 2016 SZII I6 Territory Petrol ?.
I have two different examples at home, one being AFA101 Genuine Motorcraft Air Filter. the other, Ford Care, Air Filter Element BG9601C. Cheers. |
24-08-2024, 11:21 PM | #2099 | ||
BG9601C is the correct OEM one, AFA101 is the Motorcraft Cheaper Alternate. Both will do the job.
25-08-2024, 02:53 PM | #2100 | |||
Mmm, sounds like a scammer script. Post real info if you have it. Sent from my iPhone using Tapatalk
-15 Ford Falcon FGX XR8 Auto -14 FPV Pursuit Ute #47 Auto -12 FPV Pursuit Rspec #44 Manual -11 FPV GS Ute #225 Manual -10 FG XR8 Ute Manual Sold -06 BF XR8 Ute -75 XB Falcon Coupe 351 GT replica -73 Ford Mustang convertible 351 -20 Ford Mustang GT Convertible |
