Old 30-04-2023, 10:17 PM   #1
output
POWAAHHHH!!!
output's Avatar
Default WB WD WF ECU location and wiring diagram
hey guys,
im looking as to where abouts the ECU is located..
id also like to have a look at the engine related wiring diagrams for these models.. and also the DW 121 metro (if possible)..
hopefully one of you guys can help
output is offline   Reply With Quote Multi-Quote with this Post
Old 01-05-2023, 09:27 AM   #2
russellw
Chairman & Administrator
russellw's Avatar
Default Re: WB WD WF ECU location and wiring diagram
I believe the ECU is mounted above the glove box and might be accessible by removing the plastic cover over the plenum shroud.
I've got the WSM for both the 1994 and 1997 models which cover the 1.3L engine.
Observatio Facta Rotae
