Old 22-11-2022, 07:56 AM   #1
Tim1750
Default Mk4 Mondeo dash display issues
Hi, have a Mk4 2.0 TDCI Mondeo. When engine is off, the display shows my remaining fuel and l/100km ok. When I turn engine on though it all goes blank. Any ideas?
Tim1750 is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2022, 09:59 PM   #2
Mondaveo
Mondaveo's Avatar
Default Re: Mk4 Mondeo dash display issues
Is this the standard gauge cluster, or Covers+ display? Are we taking the whole display goes blank (including odometer and trip computer) or just the fuel gauge and consumption readouts?
Best first suggestion when you don't have a clue is to get an OBD scanner and FORScan to check for any DTCs in the various computer modules. You'll possibly see one that says something like "failure to communicate with instrument cluster" or similar. We can then try to troubleshoot from there.
Other suggestion is to check your fuses - no inkling it could cause this kind of issue, but you never know and it's easy to do.
Alternatively you can try sourcing a replacement cluster from a wrecker and swap them around to see what result you get - seems extreme but it may be the easiest way depending on what resources you have available.
Hope one of those helps...
2011 Mondeo MC Titanium TDCi wagon, Panther Black
- new Powershift sensor: Nov 2016
Originally Posted by rondeo View Post
Like 'Mondeo' is possibly Latin for gearbox anxiety.
Mondaveo is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2022, 10:10 PM   #3
Tim1750
Thank you. For some reason it has since started working again. The rest of cluster worked. Just the consumption details. Will keep and eye on it.
Old 21-01-2023, 02:41 PM   #4
AlanM
When I connect FORscan, I get a DTC for the instrument display every time. And yet I actually can't find anything wrong with the instrument display! Everything seems to be working fine. Not that I'm complaining, it's just strange.
AlanM is offline   Reply With Quote Multi-Quote with this Post
