05-07-2022, 07:39 PM | #1 | ||
mechanical novice hopeful
I can't find a thread already for this? Maybe the info is buried in a more general thread somewhere?
Its for a high series bonnet. And I've got 2 with the same problem. The Lip/Trim is plastic. There are 5x 10mm nuts under the front edge of the bonnet. Then there is a double headed screw/bolt, which screws into the plastic Lip/Trim, then bolts through the bonnet to the nut. Obviously moisture gets into the bolt/not and they seize. The screw then undoes from the plastic Lip/Trim. Leaving the double headed screw/bolt attached to the nut and stuck in the bonnet. I've tried vice grips to clamp the screw head. But I can't get enough purchase to break the thread. Have tried WD40 with no improvement. Before I give up and grind them out, are there any obvious solutions I am missing? Thankyou. |
08-07-2022, 10:07 PM | #2 | ||
Next upgraded Mk1 Leopard
a bit of heat
17-07-2022, 10:36 AM | #3 | ||
Thankyou for the suggestion. In hindsight I should have thought that through for myself. Haven't been able to make time yet to try it but will report back when I have.
17-07-2022, 06:05 PM | #4 | ||
Just watch the paint.
