EBBA
Hey guys, have a AU1 Wagon which has smartlock of course, I've notice that the indicators don't work when I lock it, the parts car which was also a AU1 with smart lock did, does anyone know what makes the indicators work or 2 stop working?
would like to get them to work again so I can see when its locked from distance etc etc.. Thanks.
My Rides I've Own 94 EF Fairmont Sedan 93 EB GLi Sedan 97 EL Wagon 95 VS Exec 99 AU1 Forte Wagon - Current Daily Next XH T5 Ute (Daily/Work Ute) XG Ute (drift/skidpan project) |
Au Falcon = Mr Reliable
Have you removed the blinker flasher & swapped out with another known good one yet?
cheers, Maka
FAWD - No Boundaries
![]() Join Date: Jun 2010
Howdy, The BEM (Body Electronics Unit) controls this. I have an NL Fairlane which stopped flashing the RH indicator when locked/unlocked years ago.... then about a year ago it stopped altogether for a while... and now its one side of the other !
![]() You could try swapping the BEM out of the donor car... I think it can be done without Ford's help in the AU !?? Don't quote me though ! ![]() Dhru
View My Build thread 22 DJR Shell V-Power Mustang Eskymobile (my first EV) 07 BF2 AWD Falcon Wagon (Daily driver) 04 BA Falcon 1Tonner Ute (New Project) 03 BA Falcon Wagon (Spare) 98 NL Fairlane Ghia V8 (Weekend cruiser) 70 VG paddock racer (Cain it til it breaks.. fix it.. Cain it all over again !)
EBBA
Yeah replace flasher relay but didn't work, and have another bem but not the key and barrel that came with it.
May just have to wait when I do a Fairmont Gita dash swap
try wriggling connections at bem
if new BEM is same as old one replace and turn key on reds for approx..30min to download key to bem should start after this then key to accessory within 5 seconds switch demist switch 3 times push any button on remotes - |
EBBA
Ok will try that and see how it goes thanks
EBBA
Tried it didnt work, would only crank over but not start after waiting 30mins.
But flashers did work when I swapped it (remote came from the spare au car)
same procedure but - close doors - window down- extend time to 65-70 minutes locks should cycle -ignition off 10sec. then try-
is there a smartlock or smartshield warning light or none ?? |
EBBA
Ok will try again tomorrow, smartlock (99 model) was flashing fast.
I know this is an old thread but I have hope
![]() Did you ever solve your problem with the indicators not flashing? Mine stopped working after 19 years of working for no good reason about a year ago. I have changed the relay, no luck. My Central Locking still works fine it's just the lights no longer flash when locking or unlocking the car. I want to check the connections on the Central Locking ECU but I don't know where to find it so again I hope maybe you can help me out with that as well. ![]() |
#11 | |||
Bem is above h/brake area and controls flashers when remote is used as well as central locking and many other functions try wriggling connections You may find removing bem and carefully resoldering pins on circuit board fixes problem or you may need to replace bem Prior to 6/99 smart lock system and only requires ignition on 30 to 60 minutes to program after this it is smart shield and requires scan tool to program 2 keys etc. |
#12 | |||
