Old 11-04-2006, 04:16 PM   #1
mtbme
Default focus duratec half cut
anyone know a good reputable place to get one of these in sydney? Cheers
mtbme is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2006, 07:15 PM   #2
FRA
Mr Focus
FRA's Avatar
Whats a half cut?
Are you talking about cutting the roof and making a convertible?
FRA is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2006, 08:31 PM   #3
Talldude
Talldude's Avatar
Originally Posted by FRA
Whats a half cut?
english aint your first language aye dude..... :
Talldude is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2006, 11:07 PM   #4
b2tf
not here much anymore
b2tf's Avatar
half cut is basically a car cut in half, and you buy the half. usually the front end, they are purchase by people wanting to do engine conversions etc, its a good way of doing it.
2024 F150 XLT
Old 12-04-2006, 12:24 AM   #5
BlackLS
Can I ask what the half cuts gonna be needed for? If its not a newish Ford, I'd just go a SR20DE (non turbo): similar power, stronger build, more aftermarket goodies, cheaper, easier to access. IF your going to put the SR20 in though, you may as well get the SR20DET (turbo) in.
Very very very unlikely to get a Duratec halfcut I have to say. Half cuts are very popular with cars exported from Japan where you can buy a S14 200sx for the equivilant of $2-3000. The only burden with bringing a full car is the freight, taxes, tarrifs, compliance, grey import laws(pain in the ***) etc etc so the more popular option is get rid of the useless half of the car, freighting the front over at a fraction of the price and transplanting the good gear into an already delivered 180/200sx.
Having said that, most countries that have the Focus won't be having drastic resale drops nor make it unviable to repair a damaged car.
Cut a long story short, the only way you'll get a half cut from a Non-Jap car is if its had a rear ender and the tailgate is crushed all the way to the dash board.
FRA: Your retarded.
Old 12-04-2006, 10:27 AM   #6
mtbme
need a new model engine to meet current ADR regulations as I'm building a kit car. Will need to check out auctions - Duratec would be ideal due to 107kW & light weight. Thanks for the ideas though. If i could get away with it the SR20 or 4AGZE would be used.
Old 12-04-2006, 10:53 AM   #7
Zetec20
Zetec20's Avatar
is it for a fwd or rwd car?
Zetec20 is offline   Reply With Quote Multi-Quote with this Post
Old 12-04-2006, 09:17 PM   #8
zetec
Zoom Zoom
zetec's Avatar
I'd happily use a Duratec 2.0, they're seriously ready for some work. Applications in Europe have them running upwards of 220HP N/A, that's over 160kw. Torquey bastard of an engine, a real pearler.
2012 Mazda3 MPS
Old 13-04-2006, 12:56 AM   #9
amlohac
amlohac's Avatar
sounds like someones building a clubman, i shotgun first codrive!
amlohac is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2006, 01:07 AM   #10
omg
160kw for a modded 2.0 n/a isn't massively special to be honest, you should be able to get that with relatively few mods on a modern engine
In regards to the clubman the issue would be the gearbox, assuming it's rwd you're really going to be better off starting with something rwd to begin with. I'd be looking in the direction of S2000, MX5, renisis, beams altezza etc
omg is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2006, 02:42 PM   #11
mtbme
type 9 gearbox - can get adaptor bellhousings. These are getting common in UK but I can make an adaptor easily enough. Yes it is a clubman 600kg with 110kW good enough for me! Duratec is one of the lighter engines around & that's the whole basis of a good clubman build.
Old 14-04-2006, 12:14 AM   #12
mitch_lx
Candy White GTI
mitch_lx's Avatar
Originally Posted by BlackLS
FRA: Your retarded.
LMFAO
Why not use an all alloy Fiesta 1.6L engine !!!!: Good enough for Formula Ford.... Good enough for me !
(im not sure if the new focus motor/mazda 3 is all alloy ?? if anyone can clear that up??)
Volkswagen GTI Polo.
Candy White, Anthracite heated Sports leather seats w/ Red stitching.Tinted Windows, Eibach Pro-Kit springs,Whiteline Front/Rear adjustable sway bars,Cupra R intake, Forge Turbo Inlet pipe,BMC panel filter, APR stage one flash,
Dunlop SP sport MAXX, Forge Polished upper front strut brace. 3'' downpipe and highflow cat
Loads of fun :
mitch_lx is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2006, 01:03 AM   #13
zetec
Zoom Zoom
zetec's Avatar
Because the Focus 2.0 Duratec is also All alloy and much more powerful! Both Mazda 3 and Focus have Alloy block.
The following link might be very handy for explaining some stuff to those who don't know much about the various engines...
http://home.comcast.net/~cobar/duratec.htm
2012 Mazda3 MPS
Old 14-04-2006, 01:11 AM   #14
BlackLS
You *might* be able to use the SR20VE(basically a SR20 with VVTi/VTec), but I remember reading that the whole SR20 range was dropped coz it could no longer meet the current emissions standard.
If its going to be RWD, meeting current emissions, Id look at Lexus IS200 engine, any current cab cassis ute with RWD and a 4 pot, Mazda MX5, Volvo RWDs (is there any?)
If you think you can engineer a FWD engine to go RWD, Fiesta engine should do the trick(more likely to get a wrecked Fista than Focus as well)
Old 14-04-2006, 01:13 AM   #15
BlackLS
Ever thought of using a Alloytec V6 from a VZ, or the heavy donk from a Falcon? (these would be more cheaper and more plentyful)
Old 14-04-2006, 10:22 AM   #16
FRA
Mr Focus
FRA's Avatar
Ok. Once again I just was going through Rob's replies in here and found this one. So may I ask exactly what is the problem with asking the simple question....."What is a half cut"????? There wasn't a single problem with the grammar and it was a basic question asked in reply to one of the threads. As a member on here aren't we allowed to ask questions without being slandered????
Old 14-04-2006, 10:26 AM   #17
FRA
Mr Focus
FRA's Avatar
FRA: Your retarded.[/QUOTE]
Ok since we are all getting snotty on here about english and grammar let's have a great go at this one. FRA: your retarded?
Come on. Maybe you should go back to school and learn to spell. Because using 'your' in a sentence structure such as this one should be spelt as ...YOU'RE.
Let's get it right here boys. If your going to slander and have fun at someone elses expense at least do it with correct spelling!!
Old 14-04-2006, 06:06 PM   #18
amlohac
amlohac's Avatar
How about you all just grow the ИИИИ up and use the forum for the reasons it was designed? If your gonna ИИИИИ about each other use the private messaging system so other people dont have to put up with it. Im sure mtbme wants real replies to his question.
Old 15-04-2006, 12:23 AM   #19
Zetec20
Zetec20's Avatar
i tihnk the 'your retarded' comment was directed at the fact that a person that's supposed to know something about cars thinks a half cut has anything to do with a convertable lol, google it next time so you at least sound like you know what you're on about
Old 15-04-2006, 02:20 AM   #20
BlackLS
While where at it...
Ok since we are all getting snotty on here about english (English) and grammar(comma) let's have a great go at this one. FRA: your retarded?
Let's get it right here boys. If your going to slander and have fun at someone elses (else's) expense at least do it with correct spelling!!
Rob/Lorraine, I wasn't having a go at you for spelling or grammer.... I don't think anyone in this thread was either.
The fact is, anyone who supposedly imports car parts should know what a half cut is.
I'm from a technological background and when someone mentions that a computer has RAM already in it, I don't think of a warm woolly male sheep.
The lack of expertise of your company in this market is what brought apon my comment.
