05-04-2006, 04:04 PM | #1 | ||
quick question.
the rear main seal in the fairlane has gone and i obviously need to change it. Q is ,is it as easy as pulling the engine out to get to the seal and replace the engine or is it a bit more complicated that that? cheers
QUOTE I hope your opinion of the rear end of the VE improves because you are going to be seeing a lot of it.QUOTE QUOTE What makes you think I'm going to park behind a VE? I don't even attend the Sydney Gay Mardi Gras! QUOTE |
05-04-2006, 04:18 PM | #2 | ||
Im fairly sure you just dropped the transmissiont to get to it.
05-04-2006, 04:24 PM | #3 | ||
Performance moderator
Take the box out less cables and wires..
Consider fitting a speedy sleeve over crank ... From bearing outlets...
05-04-2006, 04:38 PM | #4 | |||
05-04-2006, 04:42 PM | #5 | |||
