Thinking of buying a mid eighty's Sierra V6....
Comments welcome. |
Cosworth version? If yes they’re getting thin on the ground and as per everything else from the UK can be pricey to work on.
I’ve toyed with the idea of a twin turbo V6 in a falcon or something a few times, would certainly be unique here in OZ if you decide to go ahead
Daily: '08 FPV F6X Territory, #82 Project 1: XA Sedan, Barra swap incoming
nice. XR4i would be great. They were never actually sold here were they?
and yes, I've got a guy on my FB feed that breaks Cosworths in England and the prices he is asking for parts is just silly. At least the V6 Cologne is a more common engine than the YB
What is the difference between the Cologne and Essex V6, if any.
Looking for clues...
Some parts are no longer available new, some of the plastics start to get brittle. There are some places that make aftermarket bits, that are interchangeable between the XRi and the XRTi in the USA.
2016 Ford Falcon FG/X XR6 Turbo you beaut ute 1985 XR4Ti Sierra - Build Thread 1971 Fairlane 500 and... a collection of Jeep Towpigs and... two collections of rust and some new plastic bits roughly shaped like an F-Truck and.... some spare metal bits with holes in them |
formerly ford3000gt
Cologne V6s are German designed and 2.8 litre Bosch fuel injected, whereas the Essex is English and a 3-litre weber twin throat carby engine used in Zephyrs and Capri's. They are completely different engines and NO parts are interchangeable!
Current ride: '83 Mk.3 Capri, 2.8i, 5-spd |
5.0 means business
And the Essex is superior
Windsor V8 Enthusiast! Turbo Barra Lover! ![]() |
#10 | |||
I wouldn't mind picking your brain over the Janspeed conversions if you don't mind. PM if you want. |
5.0 means business
Standard equipment on South African Sierra's And Sapphires.
Available as XR6 in Sierra and 3.0 GLX in Sapphire even had Efi in the last model Ghia's and Limited run of IRS and RSI models. Was available to 1993 but lived on into the Ford Courier where it also had the 3.4 version which had some issues later on when the tooling was infact getting rather tired. ![]()
#12 | ||
What did you want to know??
