Monster Burreuto
can somebody tell me if a 3.45 LSD from an EF/EL will fit in an EA? if the whole housing wont go in, can i use the center and axles from an EF/EL?
I PITY THE FOOL :ticking: |
Yep, as far as i know, you can transplant the centre and axels...
Brent
EB1 Falcon Wagon 3.9L Multipoint with 5 speed manual Pacemaker extractors & 2.5" Redback exhaust Tickford Head and Wade 1004 cam HP4 Chiptorque chip and XH intake 1992 DC LTD
5LTR DUEL FUEL |
![]() Join Date: Dec 2004
If you swap the whole diff over, you have to consider that the EF-ELs have a different handbrake cable mounting to the EA-ED diffs. So swapping the gears themselves would be best
#4 | |||
Does Steve have a car?
AKA Mr Silver Chasing reliability.... ![]() "When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
Monster Burreuto
ok, thats very good, wasnt sure if the axles would go in ok. is it a simple job of taking out the axles and centre and bolting in it back together with the new stuff? or is there shimming/adjustments required? how much would i be looking at to get a diff place to do it? thanks
5-700 for a good place to do it.. im not sure about the 2 pinion to 4 pinion i think it will be fine if you are converting the centre axles and gears
Tu Toned Ghia
can you change diff gears your self? is it hard?
#8 | |||
Well, $336 for two diffs at once that is, the 2nd diff being a mate's which is under his Falcon now. |
