15-03-2006, 11:14 PM | #1 | ||
clueless?
hey who knows what size wheels you can get onto the fiesta
every shop ive been to tells me 16s is it possible to get 17s onto the car?? |
15-03-2006, 11:27 PM | #2 | ||
yeah... i had 18s and reckon it could maybe go 19s
15-03-2006, 11:37 PM | #3 | ||
clueless?
sweet thanks man
16-03-2006, 01:44 AM | #4 | |||
GT4.
18"s are the biggest wheel that you can fit on a Fiesta. Even then you will suffer from rubbing and such. 19"S wont go without big mods. Its what every site I've researched it on has said. So 19"s? In short. No. 17"s are easily done as are 16"s. |
16-03-2006, 10:00 AM | #5 | ||
Impressive...
have you guys had a big change in NVH when you change to 17's, im thinking about a set of the LR Focus Zetec rims for my gf's fiesta.
16-03-2006, 10:40 AM | #6 | ||
Da Shifty One
Heres my 2 cents
17s Yes upto 35mm drop 18s Yes upto 15mm drop 19s No for the everyday person. Could possibly be done if all 4 inner guards are taken out with big ubderbody work and have a very very low profile tyre. I currently got 17s with 215/40R17 and the rear inner guards had to be pulled back as there was rubbing. If i do want to lower the car i would have to take the rear ones out and maybe the front.
2013 Ford Fiesta ST - Frozen White - AU 0072/XXXX
- Mountune ST180 Intake Hose - Mountune Quick Shifter - J1 ST180 MAF Adapter - K&N Apollo CAI - Triple R Front Splitter - Richbrook Shorty Aerial - DMB Gel Overlays - LED Interior Bulb Upgrade - |
16-03-2006, 12:26 PM | #7 | ||
Personally i wouldn't go past 17inch. But 19inch has been done before but it needed guard work, what kind i don't know.
COLORADO RED FIESTA ZETEC MODS - Window Tint, Bmc Panel Filter, Euro Plates, Ghia grill, Momo F16 leather gearknob, Momo Leather gearboot, WQ Zetec Front sway bar, WQ Zetec Sway bar links, WQ Zetec bushes. ICE - Alpine CDA9827, MbQuart Reference 6.5inch splits, MbQuart Reference rears, Rockford Fosgate Punch Stage 3 12inch Sub, Rockford Fosgate P4004 + P3001. |
16-03-2006, 12:36 PM | #8 | ||
GRRRR.....
If you go with 17 inch rims, use a 205/40R17 tyre, then theres no problems with clearance, and they're the right diameter, mine don't touch anywhere even after I dropped it 30mm. Theres a few aftermarket wheels around, but not too much choice in styles, I got lucky and got mine when they were on a clearance special.
BTW whereabouts are you located?
Now - 2007Renault Megane sedan, Steel Gray, 19" Koya Ambush with 235/35R19 Yokohama ADVAN V103, Eibach Pro-Kit. Gone but not forgotton - Diamond White 2004 LX Fiesta If you sneeze with your eyes open, do your eyes pop out??
16-03-2006, 12:55 PM | #9 | ||
Get in the van!
I have 17s with 205/40R17 rubber as well with no rubbing whatsoever. Biggest hassle I found was it was a very limited choice available with the offset that the Fiesta has. Although it shares this offset with the new Focus so there should be some more choices there. I also found that my car is about 20mm from bcoming an open wheeler, so wheels and tyres that are much wider may require a bit of guard work.
I never got a chance to drive my car on the standard wheel and tyre package so I don't know the actual difference in NVH, but I've found my 17s to be quite acceptable, especially for any gains in lateral grip I should have gotten.
The Dad Bus (TM): 2004 BA XT Wagon, soon to be set up as a camper and tourer. |
16-03-2006, 01:25 PM | #10 | ||
clueless?
Im in Townsville
another thing on the wheels topic when i change to a bigger size i have heard that the speedo needs recalibrated is this true? |
16-03-2006, 02:08 PM | #11 | |||
GRRRR.....
195/50R15 = 577mm 205/40R17 = 596mm 195/40R17 = 588mm BUT since there is no 195/40R17's avaliable in australia, the 205's are the best fit. My speedo reads a little low ie:100kph I think I'm actually doing about 105kph. Also I think my tyres are actually quieter than the standard bridgestones
16-03-2006, 10:36 PM | #12 | ||
striped
19's will fit if you can a rim in 19x7 with a pcd 108 and blah blah blah
so theyre few and far between, and tyres to fit the car will most likely be even harder to find if youre looking for 19's for performance increases, then you're dreaming, youre better off sticking with 17's, 18's would be too heavy and adversely affect unsprung weight. |
17-03-2006, 04:41 AM | #13 | |||
GRRRR.....
17-03-2006, 11:38 AM | #14 | ||
_ObLiViOuS_
awesome another fez owner from townsville. me too. where abouts are you? what sort of fez u own???
___Shannon___ RED FEZ>> http://i21.photobucket.com/albums/b282/_ChOwN_/6047c746.jpg |
17-03-2006, 12:14 PM | #15 | ||
clueless?
im in annandale
ive got a '04 lx 3 door i got it brand new a year and a half ago but never bothered to change anything on it so alls stock |
18-03-2006, 02:16 AM | #16 | ||
clueless?
another thing, is 4x108 the correct stud pattern for the fiesta and the offset is +38 is it
18-03-2006, 10:12 AM | #17 | ||
GRRRR.....
The offset is huge, +52 from standard, you got the stud pattern right though.
22-03-2006, 01:30 PM | #18 | |||
there was no rubbing on my car with 18s... in the end how bout u go to someone with 19s and try them and see for yourself... reading up on the net on what can and cant be done is sometimes useful... but its better for u to see for yourself. 18s will fit no problems... WITHOUT and trouble. trust me cos i had em. |
22-03-2006, 03:00 PM | #19 | ||
I agree, had three ppl in a zetec with 18's and didn't rub once during "vigourous" test drive, correct offset and width are the main factors + sidewall profile
GGR | SCT | Tein | Samco | Whiteline | Mongoose | Forge
24-03-2006, 01:02 PM | #20 | ||
Hey guys ive just put 17" Focus alloys onto my Fiesta and it looks tuff.
Now ive gotta sell my 16" Alloys. Anybody interested.. Theres 3 wheels and tyres in really good shape. One very average rim and tyre (I can buy a new rim for $188) Anyway anyone interested email me on dogs2@netspace.net.au |
