well they are Ford related, upgrading the wiring loom on FG and looks like I will need to replace those little white/cream buttons that hold the loom against the door panel......
any advice where to buy from please, or how are they released
![]() Join Date: Feb 2008
Check a fastener supply shop or the dealer.
Pop one out and take with you to show and compare that they have the right fastener. |
Can you post a pic of the clip you are referring to..
the one with cable going through
Dont p i s s off older people. At our age the term Life in Prison is not a deterrent Last edited by Tonz; 05-10-2017 at 05:25 PM. |
That is called a push type cable tie. Not sure if it is a separate part from Ford, but generic ones available like below which is a little different to genuine, but does the same job. Its basically a normal cable tie with a push in hole barb like a carpet or parcel tray plug.
http://www.ebay.com.au/itm/Push-Moun...h01mKR6Q4IXPVw |
cheers mate....thats what Iam after
Former BTIKD
![]() Join Date: Mar 2005
At $14 each I hope you don't want too many
yeah was just about to buy and hey what the ??? thank dog for search the same on ebay
As near as I can figure that $13.99 is for a pack of 100, as indicated when you select the drop down box for the length (155mm x 3.6mm x 100). Can anyone with more experience with e-bay confirm if this is the case?
I also reckon that price is for 100 of them, have look at these ones:
http://www.ebay.com.au/itm/Titan-AV-...75.c100623.m-1
476 EF XR6 Wagons - 198 were Manual 2010 Anniversary XR50 in Sunburst - 6spd Manual My Gallery Photos Here |
You'd have to make sure they're the right size for the hole you're pushing them into.
