Hi all. Does anyone know the costs of replacing clock spring in lw tread? Ford are saying that's why cruise isn't working!!!
I've done a few navaras at work and would maybe do this. Ford wanted like $650!!!! Any help would be great. Mick. |
There are two clock springs pending on if you have or do not have lane keeping aid.
This part numbers is for Focus' built from 3/1/2011 to 21/7/2015. With: BM5T 14A664 CD and is around $150 for part only. Without: BV6T 14A664 AF and is around $260 for part only. There is also another listing for 18/6/2012 to 21/7/2015 build listed for XR5 Turbo, but I think it is meat for ST as we did not get the XR5 name in Australia. Its part number is BV6T 14A664 BB and is worth around $305 for part only. |
#3 | |||
I rang parts and yeah $285 for part. Do you know how hard to remove steering wheel components? Tia. |
#4 | |||
Getting the air bag off is a bit tricky from behind once you take the shrouds off, then the wheel comes off and then the air bag is just bolts torqued to 48 Nm.. refit everything in reverse order. GT |
Ok cool thanks for that mate. It's in for transmission ATM funny the cruise button prob happened from last trans update thou?
I'll put it off for awhile I think till Xmas when when need it more and I'll do it myself. Thankyou for you help. Might pm you of I get stuck Regards michael. |
#6 | |||
Cheers, GT |
#7 | |||
All other buttons work on steering wheel just cruise doesn't turn on. I'm sure that the dealer would of checked ccc???? Have my doughts thou there abit rude bout it. I'll give they call today to say don't change part but what about checking ccc I was told by mate that they should be talking with ford Au in regards to trans to.... This cars really making wife upset |
cruise will not work if the power to the brake light switch is out like a blown fuse or they did not reconnect a wiring plug properly, check you have brake lights
#10 | |||
Yeah I know bout that and funny enough we had brake light out other day! But it tells a warning on dash. And cruise still didn't work before or after. I'll wait till we get car back and do my own checks lol |
So..... Wife picks car up gets 5mins down rd and is worse than before! Wouldn't run shaking etc. So she God back and they rd test it and then say ok will look at it another swap of baby seat into diff loan car!!! They ring up saying fixed it was engine mount that failed! Hello didn't you have that out with trans???
But the best part she gets it back and low and behold the cruise button works!!!!!!! I'm going to ring tomoz and ask why the hell they wanted to replace clock spring? So I geuss it had to do with computer reset etc. Thanks guys. |
#12 | |||
The other cause of a vibration is if the new clutch was not torqued up in a special sequence and torque value. have seen this many a time... |
