#31 | |||
i suspect that most territory cog swappers will ........barring dodgey build quality or poorly maintained ed ones will still be running nicely in ten years time with just general maintenance . its probably a bit unfair to compare the old technology , but looking at my stoneage AU which has done 240,000 kliks of varied driving from being a tow vehicle to driven like grandpa , to chirping it into second gear when a bit of youthful exuberance shows it head on the odd occasion. i look back on the nearly 11 years ive had this old banger for , and the only thing the auto has had , is an extension housing seal , an auto cooler when i first bought it , servicing by yours truly until last couple of years until old age health started dwindling a bit, and a line pressure adjustment during a service about two years ago by my new auto servicing fella. i might add the auto still sounds good and works well , it will probably out last the car i think . This to me is the big picture, yes the old torque converter auto may not quite have the driveability of the newer ones , but simplicity , reliability, ease of maintenance , cost of maintenance ,general owner satisfaction , it is pretty hard to beat imo , and you dont need a workshop computer to re calibrate everything after doing maintenance ,it just works . |
3 users like this post: |
#32 | ||
i suspect it wasnt picked up , because after the global financial crisis , bean counters would have cut back on everything ..... including longevity testing .
#33 | |||
Where to next??
Interestingly enough, the below article claims that Audi itself introduced the technology to road cars in the 80's?
___________________________ I've been around the world a couple of times or maybe more....... |
#34 | |||
I live in the country and 99% of my driving is done at 120-130k's. When I'm in the city I find the thing a right pain, constantly changing. Now I use manual mode and don't let it go over 4th. The 5.0 s/c will chug at ~1000rpm otherwise. With all these extra gears comes extra cost, imagine milkshaking a 10 speed, the cost of repair would nearly get you a new car. I was more than happy with the old BTR. Pretty much bulletproof and cheap to repair. Maybe I'm just showing my age...idk
www.bseries.com.au/mercurybullet 2016 Falcon XR8. Powered by the legend that is - David Winter. XC Cobra #181. 1985 Mack Superliner, CAT 3408, 24 speed Allison. |
#35 | ||
My Audi had 150k on the odo and the DSG was great, I liked the directness of it.
Cost of repair would be high if it died not much different to a zf in an xr6. Sign of the times car have become more disposable I guess. |
#36 | |||
Mik our one is now 9 years and 236Km and the 6 speed ZF is exactly as you described, smooth, reliable - sharp shifts, good performance mode. It's the early AWD one that is the proper ZF not the licenced version, and has had fluid replaced twice. I remember the fluid being described as 'sealed for life of gearbox' (disposable mentality?) but my mechanic reckons otherwise and the gearbox enjoyed the fluid swaps. I've asked about the 'milkshaking' and so far no symptoms, including lots of towing early in the vehicle's life. Other stuff may bust or need re-bushing, but the drivetrain will keep going a long while. |
#37 | |||
It's like shavers. Yes, twin blades are better, and triples a bit better still (although harder to clean) but do we really need 5 blades?
Time to Make the Hippies Cry Again |
#38 | ||
Bathed In A Yellow Glow
For those that say they don’t like 6 and 7 speed autos because they are constantly changing in traffic I got to say I don’t even notice mine.
It says more about the quality to me than anything else as a good box should seamlessly know where it needs to be then become more animalistic when placed into sports mode by firming up and holding the gears to the limiter when under acceleration and rev matching as it works its way back down. A had a V8 Calais a couple of years back and it’s was OEM rubbish, absolute vile as it hunted gears all over the place but I was amazed at the transformation when I had it tuned. Good software is the key. |
#39 | ||
Drivers don't need umpteen gears. The extra gears are for the fuel consumption test which is totally artificial and nothing to do with real driving. Extra gears make the fuel consumption look good on the test and that can be used in advertising. Real world driving is unlikely to get anything like those test figures.
4 users like this post: |
#40 | |||
That and the tendency for the ZF to lockup in every gear makes it painful. It might be that all the country driving has made it behave that way over time. Still painful though. Agree on the software.
#41 | ||
Powered by Marshall
I have a DSG in a 500nm Audi. Its brilliant. Lightning fast changes.
However I am under no illusion that they are infallible. I was burnt with the Audi CVT and would never own any form of CVT again. If they move to ZF I can only assume its for reduced cost and increased reliability as I cannot see it being faster to change than the DSG.
Powered by Marshall |
#42 | |||
![]() but probably not all 10 speeds, just the first few ? http://www.autoblog.com/2016/05/11/c...r-porsche-pdk/ |
#43 | ||
CVT is limited to 350nm, you wont find one in anything that has more than that.
#44 | |||
Mad Scientist!
Can't wait to see a 10 speed GT350R |
#45 | |||
2 users like this post: |
#46 | ||
Oh well no more DSG farts from the local yahoo's with they're golf's and audi's I live near a major Melb uni and there's plenty of cashed up foreign student's with these things around here hooning like crazy and doing those annoying DSG fart's.
Lot's of families around here with young kid's that are sick of it. |
#47 | |||
Powered by Marshall
My DSG is perfectly smooth. Under full acceleration with 500nm if simply keeps feeding gears seamlessly and perfectly In Sport mode is lightning quick and you can then feel the changes but in normal mode its like silk?
#48 | ||
Render unto Caesar
Wonder if Porsche will keep using their PDK, which by all reports is pretty much spot on.
Unsure how they have been over the long term but if Porsche could get it right, why not Audi?
"Aliens might be surprised to learn that in a cosmos with limitless starlight, humans kill for energy sources buried in sand." - Neil deGrasse Tyson |
#49 | |||
Where to next??
If it is limited then they just need to make them stronger to handle more torque.
#50 | ||
See... as you described "full acceleration" is ONLY where a DSG is superior...my scenario is the stop start grind of most capital cities....
#51 | ||
![]() Join Date: May 2008
I get the feeling many people who complain of a lack of smoothness in DSG's are coming from traditional torque converter auto's or even CVT's. They drive them in stop start traffic the same way they always have and in this respect DSG's will feel "shunty".
Dual Clutch gear boxes are NOT for this type of driver. They don't respond well to being "booted" from a set of traffic lights for example. They almost have to eased from rest like a manual which really defeats the purpose of choosing an auto. One of the reasons a car buyer chooses an automatic gearbox in the first place is to have smooth gear changes with no effort on the drivers part.
#52 | |||
Powered by Marshall
Throttle control is the key to a DSG and you find yourself very quickly using it very smoothly in all traffic. I really enjoy it and find it flexible when it needs to be or lazy when you want it to be
#53 | ||
Regular Schmuck
Sold my R32 at around 75k because a few guys in the VW forum I was on had their DSG go at ~120k. Quoted cost of replacement? $22k.
Noped out of that car. |
#54 | |||
Officially Fordless ![]() |
