#31 | ||
I like it, the more info the better. Especially on sportier models or models where the owner may take their car to the track.
Doesn't hurt and if people ignore it, so be it but I often glance at the gauges in my SSV and GT. I occasionally like having the Engineering mode run on my SSV which shows even more info like trans temp, throttle position etc. Just wish I could access that in the standard menu. Has anyone been able to re-program the screens to get this info easier?
FG GT...Supercharged Bliss |
#32 | |||
The Mustang by the way doesn't have an oil pressure gauge but you can scroll through a lot of engine parameters in the centre display between the main gauges. Not sure about voltmeter - haven't had enough time to play with all the features yet. It even has a cigarette lighter! (Not that I smoke!)
Currently no V8 in the garage! |
#33 | ||
Hello,
I think the Voltmeter in Cars is an evolution of an Amp Gauge. With an Amp gauge you can see if you are charging or discharging, but you need thick copper wire to connect it. Cost, and if anything happens to it, a fair risk of a fire. A Volt meter is then a safer / cheaper option. From the Voltage shown, you can see if you are charging or not. Given the PS pump being over the Alternator, most Falcon driver need advance warning. They may not fail solidly immediately, but if the Volts drop you wont want to wait to fix it. |
2 users like this post: |
#34 | ||
The one and only
Cars, like most things today are designed for idiots. 99% drivers do not know or care. They turn key, turn wheel and press peddle. Simple.
I know of a person who though the oil gauge was in liters. When it was low, he did an oil change and it went back up to 5. I can see his logic. Idiot lights are called that for a reason. I notice that the Mazda 2 (like other cars probably) that have not temp gauge. Just a light for hot and a light for cold (no light means OK)
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
