Old 11-03-2007, 01:14 PM   #1
westie13
Default need help with fuel filter
Hi guys
I need some help with fitting a new fuel filter on my AU wagon.
Its the type that has a threaded pipe one end and the clip type the other.
I have removed the filter ( the clip broke when i was taking it out to fit the new clip supplied with the new genuine filter)
My problem is i cant fit the new clip into the how.
is there a trick i need to know?
Any help would be apriciated
Scott
westie13 is offline   Reply With Quote Multi-Quote with this Post
Old 11-03-2007, 04:33 PM   #2
westie13
ok Just I have found out the answer.
There are 2 types of clips
1. The white clip that comes with the genuine filter AFG60MC and ryco filter Z528
2. small black one. ( this is the one i needed ) this one comes with a valvoline filter VF36
Old 26-03-2016, 01:06 PM   #3
parker
Default Re: need help with fuel filter
I've been caught out by this today.
No one seems to have a filter with a small clip. I'm yet to try Ford, as they're closed until Tuesday.
Why is there a mixture!
parker is offline   Reply With Quote Multi-Quote with this Post
Old 26-03-2016, 10:24 PM   #4
Davehoos
I had the same problem with my AU2 sedan.
I had a genuine motorcraft. I had purchased the double threaded filter I was assured fitted-then had to swap it.
after much issues I salvaged a clip from a 1999 AU sedan fuel pump hose.
BF11 XT EGas Wagon-SY TERRITORY AWD GHIA-
Land Rover 88
.MIDCOAST NSW.
Davehoos is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2016, 01:58 AM   #5
Blue Shadow
R.I.P. Maggie
Blue Shadow's Avatar
Yeah, its a crap idea, should all be threaded both ends
AUII XR8 200Kw Ute
FG XR6T
1976 289 Mustang (Gone)
Blue Shadow is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2016, 09:51 AM   #6
Davehoos
after I got a replacement clip I had to replace the hose due to small leak. so check.
inside the connector is an oring that had torn. some of the hoses I raided the oring had expanded out of shape.
the clip fits aftermarket replacement part.
Land Rover 88
.MIDCOAST NSW.
Old 27-03-2016, 10:28 PM   #7
parker
So Ford don't sell the little clip?
What are the replacement options? A steel line from an el or something, matched with a thread both ends filter?
You'd have to drop the tank to replace the line?
Old 28-03-2016, 08:21 PM   #8
Davehoos
You can buy the conectors and use normal fuel hose.
the hard nylon like pipe is much better-but I havnt seen this available. I use a similar hose on industrial machines but lower pressure.
My AU wagon has fuel tank removed so I cant check.
the sedan has 2 hoses from the fuel tank sender about 500mm long.. think one had a different angle on one version.
Land Rover 88
.MIDCOAST NSW.
