Hey guys, want to remove my towbar just wondering how do i take the bumper off?
Cheers !
99 AU Futura Granpa Spec |
behind each rear wheel remove 3 plastic clips from the splash trays and there is a nut on both sides either 13 or 14mm spanner required inside the boot the same 2 nuts behind the tail lights .underneath the car below the right hand tail light there are 2 pop rivets that have to be drilled out bar will slide off.instead of replacing those rivets i use 2 little nuts and bolts
#3 | |||
