Au Falcon = Mr Reliable
How's your AU handbrake going, is it operating properly or is it giving you ulcers from being recalcitrant? Any tips or thoughts on the subject, please feel free to post a thought!
![]() cheer's, Maka
Flairs - Truckers Delight
foe. Always foe.
Constantly needs adjustment. Can't apply at speed as it catches rather than coming on slowly. Ratchet in handle has worn teeth so disengages when bumped Squeaks or whooshes when adjusted improperly Possibly the worst engineered component of the AU falcon.
#3 | |||
![]() My Futura's handbrake is a friend, my Xr6's (irs) is a foe but is getting better after spending a few hours adjusting & setting it properly. That wooshing sound was a scrape for me, you could hear it coming from 20 meters away ![]() cheer's, Maka
Mine needs adjustment about once every 6 months. Be sure to adjust both sides evenly too.
To avoid wearing out the teeth you should push the button when engaging the handle, but obviously better doing this from new! I prefer to have mine adjusted to a point where the handle doesn't come up that far. Mainly 'cause I've got a boat to launch & retrieve. Prefer to know that the handbrake won't start letting go whilst I'm winching the boat up! It could've been engineered better but it only takes 10 to 15 minutes each side to get wheels on & off & adjust it. You show me a car that has no flaws, & I'll show you a mechanic with clean hands! |
Define definitive
Mines actually spot on. Haven't adjusted it in ages. Locks up mint ;)
BF F6 TYPHOON in NEO #718 ~ 356rwkw ![]() BF XR6 TURBO in SILHOUETTE |
Knucklehead
I've had no troubles whatsoever with my handbrake. Adjusted once in 60000kays and 4 years only because I fitted Brembos on the rear. Don't even put it in gear on a hill.
My handbrake needs adjusting but two things stopping me from actually adjusting it...bad weather and a bit of laziness because it's winter and I hate cold weather.
My Ride... 2005 BA2 XR6 Magnet Ute. |
#8 | |||
Is no-one else ****ted off at the fact that you can't ease on the handbrake at speed?
#9 | |||
I remember the first time i pulled my AU Futura's handbrake at speed & i thought the back end had blown up! ![]() ![]() The handbrake in it is like a on / off switch, it comes on harshly with a bang at speed, can be a bit of fun if your not aware of it, yet it operates fine when used normally. It least it operates quiet & hasn't needed adjustment for ages. Wish my Xr6's handbrake was the same actually! cheer's, Maka
Well I've never done handbrakies, if that's what ya'll are getting at. & yes, mine is no different...sounds like glacial activity if I pull it on with even the slightest of forward movement.
hasnt worked in 40thou so just leave it in park
#12 | ||
I ♥ EDM
![]() Join Date: Aug 2006
Ive had only 2 AUs where the handbrake didnt disengage fully. Obvious by the classic "shh-shh-shh" noise.
Other than that, perfectly functional. |
#13 | ||
Mines never been adjusted and I push the knob when applying it, park it in neutral everywhere I go, never leave it in gear,
#14 | ||
Spot on in the AU XR8 ute, total ***** in the AU XR8 sedan.
I've adjusted the sedan more times than I care to remember
Our Tickford cars: 2001 Congo Green AU 111 XR8 sedan, manual option 2G body kit but now wears the Rebel kit 1997 EL GT Sparkling Burgundy, sunroof, auto. Our former Tickford cars: 1997 XH11 XR8 1998 AU XR8 manual sedan 1999 AU XR8 manual ute 2002 AU XR8 auto sedan, sunroof |
#15 | ||
Mine is a POS, needs regular adjustment. Is there a perm fix for this?
Losing my patients with unfinished threads ![]() Did the ideas people helped you with work or not! ![]() |
#16 | |||
![]() Looking over previous threads on the matter, members have had good success with using a PBR major handbrake rebuild kit & making sure the handbrake cable is slack when adjusting the star wheels inside the brake hub. cheer's, Maka
#17 | ||
Hi all, after researching the subject for a while (god bless AFF
![]() For those who want to now how i went about it - (chock front wheels, safely raise & remove rear wheels, secure the rear end on stands) put it in neutral, slacken the handbrake cable, dismantle the parts assembly (brake shoes, clips, adjusters etc), then the retaining clips were reshaped (back to original shape +, be careful not to damage when reshaping) to give more bite & tension, there should be no movement of the brake horseshoe at all when fitted! Then bevel all sharp / leading edges of both shoes a bit & grease the adjusters, actuation levers plus the shoes where they sit on the adjusters with a little smear of hi temp grease before fitting. After refitting everything, there's two adjusting points for the AU handbrake system (i couldn't find a third like the BA setup). From what i've read, the way the system works is the drivers side shoe tension the left side (linked cable), so with the handbrake cable fully backed off i adjusted the drivers side first (important!) with brake hub off until slight drag when replacing the brake hub, then backed off the starwheel / adjuster about a turn or two to refit the rotor / brake hub (remember to flick the locking tab back in before refitting the rotor / brake hub). The passenger side handbrake shoes was adjusted the same as the drivers side. Definitely had more shoe wear on the passenger side because of being out of adjustment (shh shh side), that's why i took the hubs off to adjust the shoes & didin't bother with the 189.7mm factory spec. After that was all done i adjusted the cable at the handbrake lever for 8 clicks max then looked at & measured the cable actuation levers on the other side of the backing plates, both were around 8mm (spec is 6 - 10 mm) with handbrake on. Test handbrake operation a couple times then test drive (listening for the noise again), back off cable at the handbrake lever a bit more if needed upon hearing the noise. Do not pull up on the handbrake lever at all while reversing or driving ever or the shh shh noise may show up again very soon... ![]() Only pull up the handbrake lever as much is needed to safely park, you will only stretch / ruin the handbrake cable if reefing it on to max. If the noise turns up again for me, everything will be replaced with new parts (PBR major handbrake rebuild kit, thanks for the heads up Silver!) & the fun starts again adjusting it all up! ![]() ps - sorry for the long post & lack of photo's cheer's, Maka
Ford AU Series Magazine Scans Here - www.fordforums.com.au/photos/index.php?cat=2792 Proud owner of a optioned keeper S1 Tickford Falcon AU XR6 VCT - "it's actually a better-balanced car than the XR8, goes almost as hard and uses about two-thirds of the fuel" (Drive.com 2007) Last edited by Maka; 30-06-2015 at 12:06 PM. |
