Hi all,
My wife has the car above and it's currently sitting on 110,000km travelled. I've read that any time now it's likely that the timing belt will need 'doing' which is likely to be expensive, and a mate says we should move it on now before this work is done. I'm not a mechanic by any means and don't understand what's involved. Can anyone explain what will need 'doing' with the timing belt and how much it's likely to cost. If we don't get it done, what could happen in terms of damage, or does the engine just stop working or what? Any information you can offer is much appreciated ![]() Last edited by hendosrus; 28-12-2014 at 07:19 PM. |
#2 | |||
Thailand Specials
Its a pain in the *** job on any car, don't expect any change out of $1000 and it may cost more. |
Over Thinker
timing belt is now overdue for replacement
timing belts explained https://www.youtube.com/watch?v=vd5y9teII9E what year is is the car ? do you need a write up on how to do a timing belt on a 1.6 fiesta engine ? the front of the motor has to be stripped down inside the engine bay
My car goes Brumm Brumm |
Thanks guys for your helpful replies.
Now that I've seen the video, I certainly understand more than I did about what's going on. Now I have to decide whether to quickly move it on or get the work done and keep it a while longer. All he best guys ![]() |
If you like the car. If you think you will keep it for another 100K, then the belt is worth doing.
That's your decision to make. |
Its not that expensive!
$500-900 depending on who you use. throw up a location and we can give you some options. That sort of dough to get a few more trouble free years is chicken feed. |
Death B4 Decaf
Timing belt doesn't need doing until 150000km. So I wouldn't worry if I was you.
Mine isn't far off though.
06 fiesta Zetec in Tango. Factory scuff plates, mats, spoiler & leather gear knob. K&N panel filter. Focus clear side indicators. Colour coded. |
Over Thinker
we should have asked do you know if it has ever been replaced
next you should get it inspected by taking off the top plastic covers just to check its condition I always change a 1.6 or 2 ltr at the 100,000 km- or when i buy a car second hand for piece of mind
#10 | |||
I totally agree mate, for that sort of dough I wouldn't be worried. But those are not the sort of figures I've heard of unfortunately. A mechanic mate guessed at about $3.5k. I'm in Perth, so if you are able to pass a name that won't bankrupt me, I'd be uber grateful ![]() Cheers buddy, |
#11 | |||
thanks for responding. My Mrs, whose car it is, is a Kiwi too! Now, is the 150k taken from the manual or is it your opinion based on your own experience? I'm not a mechanic in any way, so I need to know I can rely on the info I'm given, if that makes sense. Cheers buddy, |
#12 | |||
thanks for the reply. I would be very surprised if it's been done as we've had it from about 50k or thereabouts. I take your point about doing them as a matter of course at 100k. However, you're probably more able in the mechanical DIY zone than me, or your service depots over there are much cheaper than ours in Perth - or both ;) |
#13 | ||
Over Thinker
I DIY mostly
never use a genuine service shop but sometimes I have had to shop around for a price on work I just cant do I use and seek out cheaper hourly rate mechanics - with low overheads - sweat sheds sometimes Kmart auto or even independent mobile mechanics
My car goes Brumm Brumm Last edited by dirty hands; 31-12-2014 at 08:55 PM. |
#14 | ||
From the Handbook for the WP (2005) Fiesta the camshaft drive belt Every 150,000km or 10 Years.
Had our Probe (RIP) camshaft belts changed at local Ultratune for approx A$1,100.00 3 years ago, including major service. Suspect there is a bit less work involved with the Fiesta. ![]()
2017 Mustang Lightening Blue, Cobb Intercooler, CAI, AccessPort, Turbo Blanket & V2 Exhaust, Mishimoto Down-Pipe & Overflow Tank, GFB DV+, Custom CRD Tune. Ford Performance Short Throw Shifter & Strut Brace. DBA T3 Brakes & Pads. Braided Brake Lines. H&R Coilovers. Anderson CF Track Pack Spoiler & Tailgate Panel. Blue CF/Leather Steering Wheel. |
#15 | |||
that's thrown some more light on it. It's a WQ model from 2006, and I've located the service handbook which shows the Camshaft Drive Belt, which I'm guessing is what we've been calling the Timing Belt, needs to be changed at 150,000kms or after 10 years - whichever comes first. So either way, it looks like I have a bit more time to play with than I first thought. But I will have a hunt round and see if I can find a reasonably priced outlet to get it done through. Thanks for your helpful reply DRU842, and to all the others who have taken time to help me. Very much appreciated ![]() Cheers, Paul |
#16 | ||
My wife has the same car (WQ). I do all our mechanical work and repairs, but the Fiesta 1.6 timing belt replacement is something I'd never attempt - it is the ultimate pain in the butt job to tackle yourself.
Firstly, the accessory drive belt needs to be removed, and this belt is a stretch belt, which has no tensioner. It must be cut off and disposed, and then a new one fitted, and special tool is required to do this: https://www.youtube.com/watch?v=wRkzBqM4uPU This alone takes time. Then, as dirty_hands said, the front of the engine needs to be stripped down in the engine bay - in this case, removal of the water pump, timing belt covers etc. Because the driver's side of the Fiesta's engine bay is so cramped, often things like the alternator, coolant tank, power steering reservoir, drivers side engine mount etc. also need to be removed to help with access. The timing then needs to be set with a set of timing tools and the timing belt needs to be installed (camshaft alignment bar and TDC locating pin), just like the 2.0L Duratec Focus engine. Then refitting of all the above. |
#17 | ||
I just bought a 2008 Fiesta with 66ks on the clock. It had a new timing belt fitted at 60k. Some people really get ripped off! I'm just glad it wasn't me. The sticker on the engine says to replace the belt again at 120k. So that's two belts before the first one is due for a change!
Should I keep the car long enough for the next timing belt change, I'm up to the challenge. No Ford dealer is going to screw me over. Recently my son and I did the timing belt on his Holden Rodeo ute. Not easy, but I have the tools to make it possible and we enjoyed the day. When it comes to the Fiesta I'll make sure I have the tools to do it too. Rule 1 through 50 before you commence a job make sure you have the right tools. You can often find needed tools on eBay for little money or refer to your Haynes Manual for substitutes. Be prepared to improvise. Often you can make the tools you need using common materials in your garage using a little ingenuity. Nothing ventured, nothing gained. What's the worst that can happen? |
#18 | ||
Re the 60k timing belt replacement.
This is a normal interval for most smal engines. I was very surprised with the Ford interval. Happy, but surprised. |
#19 | ||
The Haynes manual for Fiesta (2002 - 2008) suggests the timing belt should be changed at 50,000 miles (80,000km) or 5 years whichever comes first, especially on cars subjected to a lot of start stop driving or short journeys. The manual suggests that this interval be observed rather than 150,000km/10 years.
So given that information, the previous owner of my Fiesta did the right thing and had the belt replaced after 5 years. Haynes says the interval is very much up to the owner. As Dirty Harry would say "Are you feeling lucky, punk?" |
#20 | |||
As for what's the worst that can happen? This engine is an interference engine, with a non-keyway crankshaft, making it easier to stuff the timing, and then you have to reset, which would be a bad day at the office. What's the best that can happen? You'll have a rewarding day and save yourself a bucket load on labour costs. |
#21 | |||
2016 Mazda 3 SP25 GT 2019 Hyundai i30 Active. |
#22 | |||
It's a very nice feeling when the job is done and you turn the key and the engine fires up first go. To make sure of that you take your time and check and recheck. |
#23 | ||
3.5K?
Nah, nope never. $1000 - $1200, and that includes a ful service. And I mean FULL. |
#24 | ||
By the way, here is an example of the tool needed to fit the accessory drive belts, an how to use it: http://www.youtube.com/watch?v=xlhOSXmOW4I
(Looks like they actually use a Fiesta Engine in the video) And no, I don't work for Kincrome! |
#25 | ||
Ahh, I was under the impression that the engine had to be removed from underneath the car for the timing belt change. I wonder if it's work replacing the clutch if it's had a hard life (I believe mine has) at the same time.
SZ TS Territory TDCi '13 WQ LX Fiesta '08 XG Falcon '94 |
#26 | |||
My '05 Fiesta had a squeaking water pump and I had it done for $800 in Automasters Forrestfield. Timing belt was also included. I called around (Kmart, Ford) and it was the best price I can get. |
