Old 17-07-2014, 03:24 PM   #1
Brewtal ED
Brewtal ED's Avatar
Default Stereo and seatbelt problems same day
Hey guys,
I recently started my AUIII XR6 to be greeted by a 'wiring error, please check wiring and reset' message on my aftermarket head unit and the seatbelt light now flashing / staying on when the seat belt connected. Car drove fine in the morning but by the end of work all these issues had started.
Any ideas would be greatly appreciated before I started messing around this weekend trying to fix.
1993 ED Falcon
2.5" Full Exhaust System
Lovells Low Springs all round
2002 AU XR6
Manual, current project
2004 BF Fairmont
Stock - family car
Last edited by Brewtal ED; 17-07-2014 at 03:26 PM. Reason: forgot to mention what type of car!
Brewtal ED is offline   Reply With Quote Multi-Quote with this Post
Old 18-07-2014, 03:50 PM   #2
Brewtal ED
Brewtal ED's Avatar
Default Re: Stereo and seatbelt problems same day
may be the airbag light if that helps anyone....
1993 ED Falcon
2002 AU XR6
2004 BF Fairmont
Stock - family car
Old 20-07-2014, 12:58 AM   #3
Arch
This may not help at all however my factory stereo dies every 4 or 5 months. It's completely dead with only a led light on all the time on the unit even with the ignition off. If you pull the fuse out for a few seconds and put it back in it seems to reset itself and all is fine for another few months. Not sure what to make of it but give it a go.
All the best
Arch
Arch is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2014, 08:55 AM   #4
GK
Walking with God
GK's Avatar
IIRC, there's a sensor under the driver's seat whose connector sometimes works loose. I think it's to do with the seatbelt pre tensioner and airbag setup.
Disconnect and reconnect. That may help with the light.
I'd pull the stereo fuse as also suggested too.
Do one at a time though, as one may fix the other, and you want to be sure which trick, did the trick!
Hope it works.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 20-07-2014, 12:10 PM   #5
hales231271
hales231271's Avatar
Sounds silly but has the vehicle been in heavy rain.
I have had the issue with the airbag light and found the issue.
Down in the drivers kick panel the connection for seatbelt/seat loom is located.
This had become damp over many years and pins had corroded. Got the copper green colour due to moisture.
Finally after a heavy downpour the airbag light stayed on.
Was a bastard to find but that's what it was.
hales231271 is offline   Reply With Quote Multi-Quote with this Post
