Hi people need to know the front camber an a 95 ef falcon degrees and also if anyone knows how thick a shim needed per degree adjustment any help greatly appreciated ?
Interceptin'
Camber = Min -0.5 deg, Max 0 deg, optimum setting is -0.25 deg.
Can't remember if I was told Not to use shims or To use...but I've got a Kmac Adjustable Camber Castor Kit...works very nicely. ~ Matt
'95 EF II Falcon, 'INTERCEPTOR' '72 XA Fairmont Coupe, 'XA Muscle' |
rofl copter
my car got shimms in it, and they made it 2mm toe in. if thats any help
GQ patrol.
.... thats all |
Thanks guys great help she is running on one .5 neg and on the other 2.5 neg and as youd imagine the tyre is shagged i must check these things more often as i think me misus has hit a gutter or sumthen
