Old 24-03-2013, 09:44 PM   #1
CONGO MILLENNIUM
Default Leaking oil switch
When the daughter started our AU wagon today I noticed the valve gear sounded unusually noisy. Upon checking the oil level the dip stick was dry. After checking the filter and sump plug and noticing a very oily under side I put some oil in and started the motor, while it was idling I searched for a leak. I noticed oil dripping quite quickly from the oil light switch. Do these switches leak? Is it a Ford only part? Has anyone had to replace one? What tools will I need socket sze etc etc.
CONGO MILLENNIUM is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2013, 09:49 PM   #2
FGII-XR6
FGII-XR6's Avatar
Default Re: Leaking oil switch
common problem $11.95 at supercheap http://www.supercheapauto.com.au/onl...d=128770#Cross
[SIGPIC][/SIGPIC]
Rides:
Old 24-03-2013, 10:48 PM   #3
Papa Smurf
Papa Smurf's Avatar
Socket size is 1" 1/16. Pays to remove the Air Cleaner box to get at it easier.
Papa Smurf is offline   Reply With Quote Multi-Quote with this Post
Old 26-03-2013, 07:24 PM   #4
CONGO MILLENNIUM
Thanks for your help I purchased a new switch from autobarn and the oil leak was fixed in under an hour.
Even with the CAI removed access is tight, just took my time and kept my patcients.
