Old 03-01-2013, 10:24 PM   #31
phat_stak_tipa
phat_stak_tipa's Avatar
Default Re: Quarter Mile Calculator? Does it fit your ride?
With me in the car weighed in at 4012 pounds has made 212rwhp and i ran 14.91 it says that i should run 15.4 so its abit off.
phat_stak_tipa is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2013, 10:34 PM   #32
Trevor 57
Originally Posted by Sprint View Post
xe@1400kg, is there much left of the car?
No, all doors are gutted, plastic side windows, all dash and flooring (including deadner) gone, all interior material, seats gone, jsut a race seat, but it does have one heavy mutha-****** clevo in the front - LOL and my son tells me it is 425hp at the last dyno
Trevor 57 is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2013, 11:18 PM   #33
In Focus
2650 pounds, 180 hp = 15.047. Fairly accurate.
I haven't done a 1/4 mile myself, but Motor Magazine tested a Fabia RS at 14.97 during its Bang For Your Buck issue.
His: 2019 Ford Focus SA Trend with Driver Assist Pack: 1.5 Ecoboost 3-cylinder (yes, 3 cylinders!), 8-speed automatic in Ruby Red.
Hers: 2020 Ford Puma JK: 1.0 Ecoboost 3-cylinder, 7-speed DCT in Frozen White.
Old 04-01-2013, 08:21 AM   #34
dieseltrain79
No where near it ...
Says 12.9 . The hundred odd 11.8 second slips say otherwise ;)
1998 AU VCT Ghia - Stock as a rock - Wifes car
1991 Toyota Soarer TT - 11.72 @ 116.7mph
2004 Ford Escape XLT V6 - Family Ride .
dieseltrain79 is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2013, 10:47 AM   #35
The Monty
Just slidin'
The Monty's Avatar
Says 13.6 for me, not including driver, fuel, three baby seats, a toolbox and maccas, and I ran a 13.0.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 04-01-2013, 11:33 AM   #36
Sprint
Sprint's Avatar
Interesting so many say its on the low side when i think its on the high side.
Its only going on power to weight, so many other factors... driver,weather,setup,road,luck..
http://vexer.com/automotive-tools/1-...MPH-calculator
http://www.quartermilecalc.com/
Sprint is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2013, 11:45 AM   #37
SpoolMan
Solution Was Boost 4?, 6 & 8
SpoolMan's Avatar
Chairman's Award: Chairman's Award - Issue reason: The exceptional contribution made to AFF events and sponsorship. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Everything you do to help this place run smoothly! Technical Contributor: For members who share their technical expertise. - Issue reason: The awesome Technical and Service how to's in the FPV /XR6 /G6ET turbo threads..  and his own build threads that inspire people to have a go... enabling people to save money and realise the dream of working on their own cars as well.
says mine will do 11.23, has run 10.81.
[SIGPIC][/SIGPIC]
AUTOTECH TUNED EDELEBROCK CHARGED
2017 GT Mustang Plenty of RWKW
SpoolMan is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2013, 02:26 PM   #38
XR8menace
Says mine should do a 10.84 @ 4000lbs 620rwhp and I did a 10.96 in a manual.
XR8menace is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2013, 02:57 PM   #39
T4ME
T4ME's Avatar
It just doesn't factor in the huge torque spread from a turbo car.
Seems to be about 4-5 tenths out for a few.
03 BA Turbo
6466 external gate
Hi comp motor
Built BTR 4k TCE stall
FG inlet and exhaust manifolds
T4ME is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2013, 05:28 PM   #40
prasac
prasac's Avatar
they take way too much into account for the shift. every shift @ 2/10ths, found it works best if u just put in 1 shift, instead of say 3 or 4.
prasac is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2013, 06:45 PM   #41
Sprint
Sprint's Avatar
this description sounds like a v8 supercar
Old 27-01-2013, 01:38 PM   #42
SCTC
Originally Posted by T4ME View Post
A standard 3.8 V6 from Holden only out performed the 4.0 I6 because of the shorter first gear in the transmission,the BTR is very tall but this is where economy comes into play.
The 5.0ltr Holden motor was the same scenario to the E series Windsor 5.0.....the shorter first gear in the trans getting the torque going sooner.
Why do you think a ZF 6spd BF 6 or 8 beats the same powered BA 6 or 8?
from my testing of torque converters the smaller GMH v6 converter has 40rpm less out put speed from the input speed.While the larger Ford converter has only 13rpm less output speed than the input.Though i have not tested one, the ZF has a smaller converter similer size to the v6 GMH converter so i'd say it also has around 40 rpm less out put speed as well. It is like a higher gear except that it is in the fluid coupling of the converter.Though I have been able to get the Ford converter to slash a 10th in the 60' with standard stall. I can also get more out of the GMH v6 converter as well.VStrong Super Charged Torque Converters (TM)
SCTC is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2013, 02:12 PM   #43
SCTC
Yeah but the 1st gear in the Holden 4spd is rather short and helps with take off somewhat.
This is the reason for hole shotting the Fords all these years with the 6cyls and some 8's.
It's not the gear ratio that makes it short is what i'm trying to say, it's the converter size.If i was able to upload some pic's i'd show you some dyno comparisons that show it.A while ago I made up a extra modified GMHv6 converter to fit the Btr trans for a BA fitted and Tested at Heinrich performance and tuning in one of his cars. it come on eariler with extra 20kw right through the rev range but with slower top end speed.T4ME has the first stock stall Super Charged Torque Converter of mine in his BA and has improved his track times considerably,,as well as giving a bit better fuel economy around town!VStrong Super Charged Torque Converters (TM)
Old 27-01-2013, 06:54 PM   #44
B-series N/A 6
Wow mine needs a tune badly.
B-series N/A 6 is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2013, 11:59 AM   #45
fridaykiller19
fridaykiller19's Avatar
it says 15.4 for my fg xr6 even though my best is 14.2 so way off for me
fridaykiller19 is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2013, 06:59 PM   #46
Mont5.0
Mont5.0's Avatar
with my new found power it is saying 12.9 was pretty close before,lets see how close it will be next time i run.
FGII XR6 IN LIGHTNING STRIKE
R52 SIII IN GUN METALLIC
Mont5.0 is online now   Reply With Quote Multi-Quote with this Post
Old 30-01-2013, 10:28 PM   #47
Starlightblue
Starlightblue's Avatar
close for me - it says 10.505 and car has run a 10.46
Starlightblue is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2013, 12:19 AM   #48
XR8menace
Escort with a cleveland?! That sounds like it would be fun!!
Manual or Auto?
Old 04-02-2013, 12:39 AM   #49
Starlightblue
yeah it is a bit of fun.
its a reverse patern c4 with 4'500 stall.trans brake etc
