[AUT-747]
Hey,
So my door trims are worn in certain places by the person I bought them off. Now I have perfect donor door trims, I just want to change the leather insert bit. How can I accomplish this? Cheers, Alex. |
Cocoloko
Should just need to bend straight the metal tabs on the reverse side of the door trim..... And the arm rest part unscrews.
94 ED XR8 Sprint: SVO alloy heads, FMS F303 cam, AU EECV ECU, T5, on going build. 2010 Territory: family bus. 79 P7 LTD 351. |
[AUT-747]
thanks mate, Ill get on that this weekend !
#4 | |||
Next upgraded Mk1 Leopard
![]() Join Date: Jan 2005
http://www.fordforums.com.au/vbporta...article&id=364 Its not leather but close. UK
So is the velour insert is removable?
That is a top notch article Uncle Ken. Bill
#6 | |||
I used to work for a motor trimming business that installed leather interiors as a new car dealer's option, we used to stick the leather trim on the doors straight over the original factory fabric insert.
Some cars had fabric trim inserts as removable panels which made covering them easier. I am curious if the AU had the separate panel or one piece door trim. Bill.
'mechanically-challenged'
I'm also curious to know as I plan to reupholster the fabric insert bit with leather to match the seats in my car.
sirchAU's Galaxy Blue Falcon S
looking at te back at wreakers it looks like it melted onto the main section
