Old 17-09-2012, 08:36 AM   #31
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Default Re: T-series style headlight surrounds, and photoshop
This is BMC's (Ex JC)
Old 17-09-2012, 02:06 PM   #32
Silver'
T-Series Club Member Vic
Silver''s Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Excellent write ups on AU technical issues.
Found a couple of old beam pics on my phone...
In the first two pics, the L/H beam is not right as the bulb was not mounted correctly into the projector as I must have been in too much of a rush when fitting it...
These are Minimoto Bi-Xenon H1's with 5000k 35w bulbs running off Philips 35w ballasts. They are bright enough that I may as well disconnect my 60w high beams as it makes no difference at all.
TE2 #116
Build/Maintenance thread here.
www.fte.ford.com.au lives! 2001 2002
Add a T-series to the Registry HERE
Silver' is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2012, 12:28 AM   #33
xr6tjet
[AUT-747]
xr6tjet's Avatar
Originally Posted by SilverT2TE50
MAD is a forum member and in Melbourne's outer East. He's the man to talk to. He's done several mail-order mods to various model headlights. They arrive plug'n'play with ballasts, looms, everything you need.
On your rig, I'd try body colour painted inserts and chrome shrouds, probably the same style as mine (Porsche Cayenne Turbo 'inspired') as its hard to find anything else that suits the big AU lamps. He can fit halos to them if you like that look. He's also done coloured LED parkers behind the projector which look amazing and sure will fix those 'stock looking blues' that you have!
Al
Thanks mate, all I'm after is to have my lights painted sparkling burgundy on the bezels and for my headlights not to leak/paint peel after its done. Going for a clean look to match the car
Can anybody direct me how to get in contact with 'MAD', can't seem to find his user name using the search function.
Cheers, Alex.
xr6tjet is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2012, 12:37 AM   #34
xr6tjet
[AUT-747]
xr6tjet's Avatar
*edit * Don't worry I found MAD on the forums through Members List.
Thanks
Old 19-09-2012, 01:27 PM   #35
Silver'
Silver''s Avatar
*update* I replaced the third pic in the previous post with a better one showing the beam pattern.
TE2 #116
Old 19-09-2012, 06:46 PM   #36
xr6tjet
[AUT-747]
xr6tjet's Avatar
Paul (MAD) sends his regards for referring me to him for the headlight mods. I will be dropping my new set of headlights for a set of B5 (Sparkling burgundy) painted bezels as soon as he lets me know when.
Cheers, Alex.
