Hi guys
I've got an EB Ghia V8 that is my daily driver and I'm looking for any ways to improve my fuel economy. I do ~60km a day. About 90% of my driving is highway, cruising between 80-110kmh. My current fuel economy is between 12-13l/100km. Mods are - Extractors, 2.5" exhaust, EL GT snorkel. The car is a 5.0 auto with a 3.23 lsd. Are there any simple/cheap things I can do to improve my economy, has anyone had any good results with J3 chips? any driving techniques that can help? BTW Replacing the EB with a more efficient car is out of the question ![]() |
OzEcruisers PRESIDENT
![]() Join Date: Mar 2005
That seems high for mostly highway driving
I have a 6 that's had a lot of work done to it together with a 3500 histall and mind is around that with mostly mountain driving @ 60klms/h - going up a hill with 3500 histall is like riding the clutch all the time I would take it to a Dyno Tuner and run it up on the Dyno to see if it's stock tune and afr's are correct - obviously you service it properly, new spark plugs, new leads, fuel filter, oil filter, exhaust doesn't leak and cats aren't blocked If you Dyno it they will be able to give you a better idea
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan PROEF 13.46 @ 105.78mph Tuned by DYNOMOTIVE 200BUX - AFF Drag Nats 2019 EF Wagon
Also consider replacing the O2 sensors and maybe cleaning out the MAF?
My old XR8 (EL 1 so same engine as yours) had 3.45s and I used to get better fuel economy than that with the same mods so there is definately some improvement to be had. |
Yeah it does seem pretty high fuel usage for the driving that I do.
I'll change the plugs soon - no idea how old the current ones are. Same with the fuel filter. The exhaust seems fine, the engine revs out cleanly (as cleanly as a E7TE headed Windsor can anyway) and it doesn't feel like the cats are blocked. Can I clean the MAF using electrical contact cleaner? |
Has anyone successfully cleaned their old 02 sensor and found better fuel economy?
My Ride... 2005 BA2 XR6 Magnet Ute. |
on the way to the RSL
Pump the tyres up really hard? Used to work on a pushbike lol.
ED GLi - DOHC - GT42R - 2 Speed - 275 Radials- Moser 9" 8.9x@160mph+ |
#7 | |||
I dont think you can really clean O2 sensors
WTB. Black BF front door trims, BF wagon books, terry ducting.
The Daily's Build. http://www.fordforums.com.au/showthread.php?t=11349360 Weekender: '69 VW Notchback http://www.fordforums.com.au/showthr...24#post4531824 |
check your brake calipers arent sticky or frozen.
xy 351 11.78@118mph daily driver |
yes contact cleaner works on the MAFs, I use it on mine.
Tyres were 32psi front 23psi back, so I pumped them up to 40psi front 36psi back lol.
Cheers I'll give the maf a clean and see if it makes a difference. |
