Old 21-11-2005, 11:42 AM   #1
vegabass
BASS ON BOARD!
vegabass's Avatar
Default Stalling
Hi fellas just need to know if this is a common problem,
I have finished the T5 conversion and have wired up the resistors and the linear pot to the auto ECU. now it stalls when pulling up to a stop. the revs will fall and it will become realy rough.....then stops.
i know drive is ment to be 2.5V (in the pot) but my car wouldnt idle so i had to put it to 3.9v for it to be happy.
any ideas?
Would a after market management system or a Chiptorque chip fix this?
any help you be great thanks guys
Nothing interesting to put here.
vegabass is offline   Reply With Quote Multi-Quote with this Post
Old 21-11-2005, 11:51 AM   #2
oneredED
need more boost
oneredED's Avatar
I have yet wire up anything on mine other than the speedo wires and earthing the starter relay... and it runs fine :P We'll have to wait and see what happens when i cam+extractors it...
'94 ED Falcon GLi
Suspended by: kings, koni, pedders
Rolls on: 17" AJR Director's
Stops due to: bendix, DBA
Shifter connected to: T5 manual
Power from: ???
Interior: velour and woodgrain
Cost: stuff all :P
oneredED is offline   Reply With Quote Multi-Quote with this Post
Old 21-11-2005, 12:13 PM   #3
vegabass
BASS ON BOARD!
vegabass's Avatar
Yeah mine runs fine as well it will sitt all day and idle happy!
just for example pulling up to stop as a set of lights and pop it back to 2nd.....then a few meters from the stop line you put the clutch in and thats when it gets upset and stalls.
so i think i will speak with chiptorque or JMM to see which is the best way to go to fix the issue.
Old 21-11-2005, 12:26 PM   #4
DUMTEF
DUMTEF's Avatar
i had a similar problem after fitting a new motor and a 5 speed in my old ea, and it ended up being the map sensor from what the mechanic told me
DUMTEF is offline   Reply With Quote Multi-Quote with this Post
