28-11-2011, 11:23 PM | #7 | ||
Dont throw it away . Its designed to help with airflow through the radiator and Air con condensor .
Its all about creating air flow , air speed , and high low pressure zones in the engine bay to extract heat . If the bolt holes have failed you could always drill and cable tie , problem is , makes it a bit more diffivult when you want to remove and refit when working on the car , or try your local wreckers . New for $80 isnt a bad option if you cant find one .
1998 AU VCT Ghia - Stock as a rock - Wifes car 1991 Toyota Soarer TT - 11.72 @ 116.7mph 2004 Ford Escape XLT V6 - Family Ride . |
