Old 28-09-2011, 02:53 PM   #1
casabonka
You can call me Chris
casabonka's Avatar
Default Stereo Fascia Removal?
gday Guys,
I have got hold of some carbon fibre vinyl and will be popping this on in the next couple of days around the stereo fascia.
How hard is it to remove just the fascia or am I better off just sticking it over and cutting out everything with it still intact?
Its an LS if that makes any difference
Chris
'06 LS Focus Hatch
-2 1/4" Lukey Exhaust
-RDA Slotted discs/Greenstuff pads
-Rear Whiteline swaybay
-Lenso 18's w/Kumho rubber
-Tinted Windows
casabonka is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2011, 04:39 PM   #2
ConradP
ConradP's Avatar
Default Re: Stereo Fascia Removal?
I don't know personally, but how much did you get it for? I've seen the pre-cut carbon fibre things for several hundred and wanted but really it's not worth that much for the surrounding of your stereo.
2010 LV Focus LX Titanium Grey - K&N Apollo CAI - 2" Cat-back Exhaust -18" Black with machined front RS rims - DRL/Halo Headlights - Eibach prokit springs - Front Strut Brace - Black XR5 Spoiler
Plans: Whiteline Rear Sway bar
ConradP is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2011, 05:41 PM   #3
casabonka
casabonka's Avatar
I work in signage so was just an offcut. it is pretty exe though!
'06 LS Focus Hatch
-Tinted Windows
Old 29-09-2011, 08:04 AM   #4
LordFordNZ
I am replacing my radio on my LV with an aftermarket chinese unit, and as part of my homework looking into this, I did come across a couple of video's on You Tube - though had a quick seach and didnt see the one i was looking at, though there were others there that may help. I would be inclined to remove it to cover it properly...it will get a much better job and probably be quicker in the long run.
Here is an ebay link that may help - its a video, while its more focused (pun intended) on radio replacement, it does show that in order to get the fascia off, you need to remove the radio, which requires the little knive things you slot in.
http://www.ebay.com.au/itm/EONON-D51...item1c1d3da51e
LordFordNZ is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2011, 01:56 PM   #5
#Russ#Es#
Hello Koni's!
#Russ#Es#'s Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: This member has made a few valuable contributions to the Forum in the Focus section, seems to know exactly what he is talking about with his posts, which are helpful and concise.
Yep, remove the CD player with stereo removal keys (at your door for less than AU$5.00). Have done mine, would be much neater job to remove than to apply with the fascia still fitted.
2006 LX FOCUS SEDAN
Titanium Grey, factory bodykit, slightly debadged
CSA Motorvatr 17's/Kumho KU31's, Eibach Prokit/Lovells rear springs, Koni Sports Kit
Lower airbox removed, K&N Panel filter
Momo gear knob + boot + pedals, Ghia boot garnish, Zetec Chrome interior door handles
JVC KW-XR816 Headunit + more to come...
#Russ#Es# is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2011, 09:04 PM   #6
casabonka
casabonka's Avatar
thanks for the advise guys!
'06 LS Focus Hatch
-Tinted Windows
